PIP position changes after rightclicking to fill up the screen
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
vMix has this option:
Picture In Picture Zoom
When an overlay is active and set to "Picture In Picture" mode you can right click the numbered button to expand it to fill the screen.
Right click again to reduce the size back to the Picture In Picture settings.
After the second rightclick the postion is changed (vMix 12.0.0.120).
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
I have done a quick test of turning on a Picture In Picture overlay which is displayed in its configured position. I right click the overlay and it expands to fill the entire screen. I then right click again and it reverts back to the Picture In Picture settings.
All appears to be working as expected. If you think it is not going back to the original position, could you provide a before and after screenshot?
Thanks,
Martin vMix
Thanks,
The bug appears to be related to using the Normal or 4:3 aspect ratio. It works ok in widescreen which is why I missed it.
This should be fixed in the next update.
Gotta say I absolutely love this feature I found by accident a couple weeks ago.
