3rd Party Software and Development
Put makin and markout to videos from a videolist post
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Greetings to all, I want to know how a script would be made to be able to put the input and output marks to the videos of an entire VideoList input, is this possible or it should only be done manually. As an example, in the VideoList input there are between 14 or 18 videos, mp4 videos must start 12 seconds later and mkv videos 7 seconds and all videos must end an average of 11 seconds before the video ends. Translated from Spanish to English by google translator
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
You will be better off batch converting (trim) these videos with ffmpeg or something before putting them in your list seeing you know ahead of time the trim criteria anyway.
This is what is being done with a converter but there have been problems with certain videos that it does not want, it does not accept the problem is that it leaves them as it does not touch them, well I will change with another converter, but vmix plays them normal and that is why I was looking for some solution with the marks IN OUT, I will look for another converter. thanks for everything.
