65 Pages«<5253545556>»
elgarf
#1061 Posted : Monday, January 4, 2021 3:14:01 AM(UTC)
elgarf
Russian Federation
Was thanked: 229 time(s) in 129 post(s)
@Chircanu, hmm... even if update lies in the same folder?
Chircanu
#1062 Posted : Monday, January 4, 2021 3:38:57 AM(UTC)
Chircanu
@elgarf, to be sure that everything is ok, I always created the WIDGET NDI Monitor widget again or I put the dll in that update
marek69
#1063 Posted : Monday, January 4, 2021 4:25:14 AM(UTC)
marek69
Poland
I downloaded again, unfortunately, continue this happens ... :(
elgarf
#1064 Posted : Monday, January 4, 2021 3:28:23 PM(UTC)
elgarf
Russian Federation
@marek69, try remove monitor widget and create it again.
Or just add new monitor widget. Is it working?
andreserio
#1065 Posted : Tuesday, January 5, 2021 1:40:58 AM(UTC)
andreserio
Brazil
I have the same problem.
When trying to remove NDI Monitor from a preset, UTC stop.
elgarf
#1066 Posted : Tuesday, January 5, 2021 2:38:54 AM(UTC)
elgarf
Russian Federation
@andreserio, is this true for today version?
I changed something in external data widget code.
qfproducciones
#1067 Posted : Tuesday, January 5, 2021 6:40:26 AM(UTC)
qfproducciones
Ecuador
Hello i just start using UTC, is awsome, i only have one problem with the ndi monitor i put the ndi monitor, and cant see anithing from my monitor, everithing else works perfect, and other question, hoy can i program a funccion to make the replay in the utc, thank you very much
One controller to rule them all
Configurable controller for vMix, working through official web API.
Switching, scripting, titling, monitoring, routing and many more use cases are possible with UTC widget system.
Tips and use cases
There is no official documentation yet, but I'm work on it (slooooowly).
First steps into describing all features
UTC Wiki
Here's thread with use cases and tips for UTC, maintained by DWAM.
vMix UTC how to get started, use cases and tips
Downloads
Universal Title Controller (updated 04.01.2021)
Source Code on GitHub
Generic Xml Data Provider for UTC
NDI Monitor Data Provider for UTC (updated 01.01.2019)
NDI Monitor Data Provider for UTC (dshow version) (updated 10.08.2018)
Changelog
Old versions
If you have any problems, please attach last log to your post. It's in "Documents/vMix UTC/logs" folder.
Also It's better to look at windows event viewer (because crash can be not added to log).
Feel free to post comments.
P.S. Thanks button is in the bottom right corner of UTC window
Chircanu
#1068 Posted : Tuesday, January 5, 2021 7:49:48 AM(UTC)
Chircanu
Greetings to all, @elgarf, a great request I have. I can not make UTC work on another device (laptop). Vimix runs on another drive, and on the laptop I would like to run UTC for graphics and others. I wrote the IP generated by vimx, shows synchronization up to the yellow stage after which it stops. If I synchronize empty UTC (without a previous save) and create the widgets again works, but I want to load a previous save stops. A word of advice, please, what should I do? Thank you so much!
elgarf
#1069 Posted : Tuesday, January 5, 2021 5:49:14 PM(UTC)
elgarf
Russian Federation
@qfproducciones, can you see NDI streams in another software? How look like your NDI monitor? Just "properties" button or two combo boxes and checkbox?
@Chircanu, can you share controller in PM? I don't have second laptop right now, but can try it locally.
andreserio
#1070 Posted : Wednesday, January 6, 2021 8:15:33 AM(UTC)
andreserio
Brazil
Yes
Only in the latest version. And even if I try to create a new preset, when adding the NDI monitor, I don't have the option to select my computer, even if I click on the properties and add the NDI Monitor DLL.
qfproducciones
#1071 Posted : Thursday, January 7, 2021 10:36:13 AM(UTC)
qfproducciones
Ecuador
System.InvalidOperationException: Error en el documento XML (17, 421). ---&gt; System.Xml.XmlException: Fin inesperado de archivo al analizar Name. línea 17, posición 421.
en System.Xml.XmlTextReaderImpl.Throw(Exception e)
en System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
en System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String arg)
en System.Xml.XmlTextReaderImpl.ParseQName(Boolean isQName, Int32 startOffset, Int32&amp; colonPos)
en System.Xml.XmlTextReaderImpl.ParseElement()
en System.Xml.XmlTextReaderImpl.ParseElementContent()
en System.Xml.XmlTextReaderImpl.Read()
en System.Xml.XmlReader.ReadElementString()
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read23_vMixControlExternalData(Boolean isNullable, Boolean checkType)
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read40_vMixControl(Boolean isNullable, Boolean checkType)
en Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read41_ArrayOfVMixControl()
--- Fin del seguimiento de la pila de la excepción interna ---
en System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
en vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
en vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
P.S. Don't be afraid, your controller is OK.
Report about it on forum.
classis
#1072 Posted : Wednesday, January 13, 2021 4:03:58 PM(UTC)
classis
Russian Federation
Hi all.
I have problem with UTC.
Source: Application Error
Date: 13.01.2021 8:52:36
Cod: 1000
Category:(100)
Level: Error
Key words: Classic
Application name: vMixController.exe, version: 1.1.198.5935, time stamp: 0x5ffbd628
Module name: clr.dll, version: 4.8.4250.0, time stamp: 0x5f2a0630
Код исключения: 0xc00000fd
Смещение ошибки: 0x004d4e0a
C:\Users\it\Downloads\vMixUTC_Donateware (11.01.2021)\vMixController.exe
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
This is a brand new PC with clean install Win10Pro. Reinstall doesn't solve this problem.
Anyone know how to fix it?
TheMadPear
#1073 Posted : Wednesday, January 13, 2021 10:30:42 PM(UTC)
TheMadPear
You have been a member since:: 12/24/2020(UTC)
Canada
Originally Posted by: classis Go to Quoted Post
Hi all.
Cod: 1000
Category:(100)
Level: Error
Key words: Classic
Try to repair your .net framework using the following tool: https://www.microsoft.co...ad/details.aspx?id=30135
thanks 1 user thanked TheMadPear for this useful post.
classis on 1/15/2021(UTC)
elgarf
#1074 Posted : Wednesday, January 13, 2021 11:15:37 PM(UTC)
elgarf
Russian Federation
@qfproducciones, that's strange. What about send me controller in PM?
magicnb35
#1075 Posted : Thursday, January 14, 2021 6:15:03 PM(UTC)
magicnb35
Angola
Using version 1.1.2021 update shows NDI if using version 1.4.2021 not using NDI display
elgarf
#1076 Posted : Thursday, January 14, 2021 10:10:26 PM(UTC)
elgarf
Russian Federation
@magicnb35, I forgot to change date in first post =(
There was version from 11.01.2021, btw, I just made update with 14.01.2021 version.
thanks 2 users thanked elgarf for this useful post.
Chircanu on 1/14/2021(UTC), magicnb35 on 1/18/2021(UTC)
classis
#1077 Posted : Friday, January 15, 2021 3:02:26 AM(UTC)
classis
Russian Federation
Hi all.
Cod: 1000
Category:(100)
Level: Error
Key words: Classic
Thx. It's really help me
fadytabar
#1078 Posted : Saturday, January 16, 2021 4:13:02 AM(UTC)
fadytabar
Lebanon
Thank you so much for this awesome utility.
A quick suggestion, i am not sure if it's already there and i missed it...
Can we have the option to apply a thumbnail from the actual input to a button instead of manually choosing an image?
Similar to the option available in Vmix Shortcuts, in Display option (Default, Color, Image or Thumbnail)
Many thanks.
FT
elgarf
#1079 Posted : Saturday, January 16, 2021 9:53:02 PM(UTC)
elgarf
Russian Federation
@fadytabar, I think that's not possible now.
vMix generate thumbnails only for shortcuts, id of shortcut is not corresponding with input key =(
thanks 1 user thanked elgarf for this useful post.
fadytabar on 2/10/2021(UTC)
amir29918
#1080 Posted : Monday, January 18, 2021 5:31:04 AM(UTC)
amir29918
Iran (Islamic Republic Of)
Hi @elgarf
Please add a section to change name of layout pages...
And UTC can't support shapes on gt title designer for change color or SetXVisibleOn or off and ........
Guest (14)
