Peter1000
#1 Posted : Friday, January 1, 2021 7:43:10 PM(UTC)
Peter1000
Switzerland
Was thanked: 82 time(s) in 62 post(s)
I have been looking for a simple solution for growing bars with the GT Title.
Here now my example, how I tried to solve this.
The gtzip template has ONE bar, consisting of 579 individual text fields (hard work :-), each 3 pixels wide, each with the character "full block" of Arial █
Load the GT title growingbars1.gtzip into vMix.
Adjust the size and position of the first bar with the Position sliders of this Input.
Create 3 virtual copies of this bar.
Move them with the Position sliders to the right position in each Input.
(IMPORTANT) Rename the 3 copies to:
growingbars2.gtzip
growingbars3.gtzip
growingbars4.gtzip
load a Color Transparent input.
add the 4 growingbar titles to the multiviewer.
This input is then your finished overlay signal.
For the bars to move, 2 scripts are needed.
one to clear the bars
one to make the bars grow.
The scripts are loaded with the preset.
for testing, please put all parts on the desktop.
-Project growingbars.vmix
-GT title growingbar1.gtzip
All necessary variables can be changed in the script growingbars.
(color,transparence of the bar, speed, percentages)
The script is designed for a total of 100%.
The bar width is adjusted automatically, i.e. the participant with the highest percentage gets the full bar width.
Shortcuts:
C clears the bars
G starts bars growing
All needed files (project, titel) are here
thanks 1 user thanked Peter1000 for this useful post.
AGUS2572 on 9/29/2022(UTC)
#2 Posted : Friday, January 1, 2021 9:44:10 PM(UTC)
Nicely done Peter
579 individual text fields ????
One for the bar and one for the value (percentage) :-)
One constant running script to translate user value (could be from datasource) , another if one wants to do a full grow or shrink animation
LMTunkara
#3 Posted : Wednesday, November 10, 2021 10:55:54 PM(UTC)
LMTunkara
Gambia
Firstly, thanks for sharing your work.
I was wondering, how can I make a bar that changes size based on data input? I am working on an election package and want to make a bar graph that represents the various percentages candidates receive?
Cheers
Lassana Tunkara
#4 Posted : Thursday, November 11, 2021 12:40:56 AM(UTC)
Cheers
Lassana Tunkara
Thats what all the above does. There is also another post in this forum from someone who created something for election results
LMTunkara
#5 Posted : Thursday, November 11, 2021 12:52:20 AM(UTC)
LMTunkara
Gambia
I see. Let me dl the files and see if I can work it out.
Cheers
recrieprodutora
#6 Posted : Wednesday, November 2, 2022 4:31:47 AM(UTC)
recrieprodutora
Brazil
Originally Posted by: doggy Go to Quoted Post
Nicely done Peter
Is there an update for this script?
Could you share how you arrived at this result? The script or .xaml format?
Thks!
#7 Posted : Wednesday, November 2, 2022 5:13:25 AM(UTC)
Thks!
GT title (designer)
A textfield and a colored rectangle
Textfield set to automatic resizing to width
crop/mask the rectangle with the textfield
number of character in textfield will determin the length of the rectangle
A vMix vb.net script that reads a value (from title/datasource, or other) and converts it to a number of characters needed/set within the bar textfield (a percentage of max length of the bar for example) or just a length of text entered manually if one wants to avoid some math ;-)
Step resolution of the bar is related to the font size used
That's it
randigusti
#8 Posted : Monday, December 11, 2023 7:44:20 PM(UTC)
randigusti
Indonesia
hello doggy , i am newbie at scripting. can you please help me make the script can growing the bar base from countdown
