Slaver
#1 Posted : Wednesday, November 18, 2020 4:55:07 PM(UTC)
Slaver
Rank:: Advanced Member
Was thanked: 8 time(s) in 8 post(s)
Hey Folks,
i need to build a scoreboard for basketball in the gt title designer and need to know if several things are possible:
1. when the time is running the color of the numbers has to be green and when it stops it has to be red
2. in the last minute of a quarter the time has to changed from minutes and seconds to seconds and tens of a seconds
Thank you so much
#2 Posted : Wednesday, November 18, 2020 5:09:14 PM(UTC)
GT Titling does not handle logic itself but other than that for displaying (same as with XAML titles) :
1. YES (what is controlling the change run/pause ?)
2. YES (better have scripting capabilities)
Slaver
#3 Posted : Sunday, November 22, 2020 4:39:58 AM(UTC)
Slaver
Thanks @doggy
1. Its controlled by a start/stop shortcut (PauseCountdown).
2. Can you give me a hint where the scripting has to be made?
Thank you!
#4 Posted : Sunday, November 22, 2020 5:38:04 AM(UTC)
Use same shortcut to change color of text in the title
In the scripting section (settings)
Check out "scripting for dummies "post
The "problem" with your goal is that the clock display formatting will have to be handled by the script. Basically a hidden clock in your title read by the script and reformatted for display in the visual location
Slaver
#5 Posted : Thursday, December 31, 2020 6:36:16 AM(UTC)
Slaver
okay, my challenge just changed a lot.
I get the scoreboard data by vMix API. So there is no shortcut to change the color of the time.
Shotclock, Gametime, ScoreHome and ScoreAway are running well. But i also get the period and the Teamfouls. Problem is that the Period is coming in 1,2,3,4 and i need it in 1/4, 2/4, 3/4, 4/4. Also the teamfouls has to show as a graphic and not just the number (1,2,3,4,5....)
Thanks in advance.
#6 Posted : Thursday, December 31, 2020 5:12:45 PM(UTC)
I assume through a DataSource instead
Scripting (check out scripting for Dummies post )
Add /4 to the Datasource format in Title editor ( {0}/4 )
Again scripting to check the value and based on that replace the image or maybe change title page or similar
Slaver on 1/1/2021(UTC)
Slaver
#7 Posted : Friday, January 1, 2021 2:24:33 AM(UTC)
Slaver
@doggy
First of all, thank you for your help and all the hints in 2020.
I don´t get the data by data sources. It is sending directly in to the input because of the delay of the clocks which shows also the tenth of a second. The scoreboard data is sent by a raspberry pi into the network to my vmix pc address 192.168.1.10:8099/1 It is running perfectly instead of the problem not to be able to edit the data.
You know what i mean?
#8 Posted : Friday, January 1, 2021 3:04:17 AM(UTC)
@doggy
Not really , what type of input is the data being displayed in ?
kross
#9 Posted : Saturday, January 2, 2021 3:15:33 PM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
If you're using the SetText API shortcut to set the text, there's also a SetTextColor API shortcut as well. Won't that do what you want?
Slaver
#10 Posted : Sunday, January 3, 2021 12:02:10 AM(UTC)
Slaver
@doggy
I don´t know how to explain it in a better way that you can understand.
Facts:
The scoreboard data is sent by a raspberry pi into the network to my vmix pc to address port and input number in vMix by 192.168.1.10:8099/1 (Thats the IP address of my vMix computer.) It send the data into the input and it is getting into it when i have a XAML oder GZIP where the fields have the same name like the data inputs i send by network.
Here is a good explaination of what i mean:
https://scoreboard-ocr.com/vmix
Thanks!
#11 Posted : Sunday, January 3, 2021 12:20:55 AM(UTC)
@doggy
Facts:
Thanks!
ok, basically datasource similar
check out "scripting for dummies" post as there are a few ways described there to how to retrieve the values from your title and make decisions on what to do with them. thats the easiest and flexible way of making decisions based on data in a title ( might have to add a few dummy textblocks in your title depending if the content itself has to change or not )
1. the script check to see if the time is changing ( still running ) if not set the textcolor to red else to green
2. check if the time is less then a minute, if so change the display formatting of the time string
Slaver on 1/4/2021(UTC)
Slaver
#12 Posted : Monday, January 4, 2021 4:21:48 AM(UTC)
Slaver
I will check that. Thank you doggy.
