stussi
#1 Posted : Saturday, March 22, 2014 7:50:43 AM(UTC)
stussi
Hi, I would use vMix to stream both primary and backup streaming on akamai. This kind of streaming needs authentication and I always do that correctly with FMLE.
The primary stream works fine but from connection log I see that when vMix try to connect to backup stream appear this message: "Credential required to connect to server. Cannot query credentials interactively".
In my opinion vMix send credentials only on primary stream. The credentials are the same for both primary and backup stream.
When I use FMLE from command line, I use this kind of command for giving credentials on both primary and backup stream:
FMLEcmd /p C:\streaming\profile.xml /ap user:password /ab user:password
I think that vMix send only /ap credential command for primary streaming.
Can I solve this issue with a workaround?
Thanks.
#2 Posted : Saturday, March 22, 2014 8:21:20 AM(UTC)
Hi Stussi,
The missing /ab command is an oversight I have fixed in the following update:
http://www.vmix.com.au/download/vmix12.120.exe
Please install and confirm it solves your issue.
You will need to enter in separate username and passwords for the backup stream in the Streaming - Advanced window.
stussi on 3/22/2014(UTC)
stussi
#3 Posted : Saturday, March 22, 2014 10:41:56 AM(UTC)
stussi
admin wrote:
Hi Stussi,
It works perfectly, thanks!
