Cannot get audio on bus C-G
Hi all, I'm strugling with this for many hours now. I cannot get any audio signal on the busses C-G. I have enabled the busses under settings>audio outputs. I've tried several settings there: just "enabled" or sending them to hardware or VB-cable. And various settings for the channels 1+2, 3+4 etc. (Frankly, I might not fully understand this part of the settings, where do the numbers refer to? Perhaps this is the culprit?) I have also checked all boxes in the channel matrices of the input channels. All busses show up Whatever I've tried, I don't see (bus VU meters) and hear (assigned outputs) any audio on the C-G busses. For the A & B bus, I can get signals by selecting the A en B buttons in the audio mixer. I don't see C-G buttons appearing. Is that normal? I attached screen shots of some audio settings. Bus A gets a signal becuase I activated the A button of some a channel. But how do I get this signal to the C-G busses? What do I miss?  Knipsel2.PNG (19kb) downloaded 0 time(s). Knipsel1.PNG (20kb) downloaded 0 time(s). Knipsel3.PNG (12kb) downloaded 0 time(s).
Joined: 10/26/2020(UTC) Posts: 76  Location: Maryland Thanks: 2 times Was thanked: 26 time(s) in 20 post(s)
You still have to assign the source to the bus. C-G are a little more hidden. Right-click the A or B buttons on the desired source and a menu will pop up for C-G.
 1 user thanked Babbit for this useful post.
Originally Posted by: Babbit  You still have to assign the source to the bus. C-G are a little more hidden. Right-click the A or B buttons on the desired source and a menu will pop up for C-G. Aha! That's the trick! Thanks!!!
if only ... ;-)  busc-g.JPG (45kb) downloaded 1 time(s).
