3rd Party Software and Development
[FREE] Vrac - Remote Audio Controller for Vmix
Joined: 10/5/2020(UTC) Posts: 6  Location: Paris Thanks: 4 times Was thanked: 13 time(s) in 4 post(s)
VracThis software allows you to monitor and control the audio of vmix remotely. You can use it in local, LAN or WAN (internet). DownloadNormal versionOne-file version ( can trigger windows defender ) Quick launch in LAN1- Launch vmix, open your session 2- Launch vrac, type the ip address of the host vmix pc 3 - Once connected, click on 'GetAllInput' button to get all vmix input 4 - Enjoy ! :) for WAN launch, you have to open a port on your ethernet box, with as redirection port the 8099 of the vmix pc.  vrac.PNG (952kb) downloaded 120 time(s).Changelog
Vrac 0.9 (18/01/2021) - Mute button, volume fader and routing are now linked to vmix - The routing window is now expandable, and the size of the input texts is larger - You can now change the size of the inputs fader, to display more fader on your screen - Vrac don't crash anymore when the connection is interupted - Add donation button, if you want to support this software ! Resize demo
Features- Audio/Video Feedback for monitoring
 Vmixcall.PNG (9kb) downloaded 46 time(s).Allows connection to a vmixcall without needing a camera and a microphone. You can choose wich audio bus you want, control the sound of your monitoring and see the return of the program. Setting up :1- Vmix side, create a vmixcall input 2- Rename it 'Audio Feedback' 3- Vrac side, click on 'Turn on Audio'
- audio input monitor and control ( volume, gain, mute, solo ) - rename input / bus fader like you want - Rooting window
 RootingScreen.PNG (10kb) downloaded 30 time(s).Allows you to easily manage vmix audio rooting
- Shortcut
 ShortcutWindow.PNG (9kb) downloaded 28 time(s).create shortcuts to perform actions of Vrac. You can perform actions with several faders, by adding ',' between channel id You can also save and restore your shortcuts.
 8 users thanked JejeSwag for this useful post.
Oh Oh ! Prometteur ! On va tester ça !
Rooting ou Routing ?
Joined: 11/24/2020(UTC) Posts: 10  Location: Chamigny Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
Thanks for this post, a very very good way to control our audio. I love it.
In my two vmix PC I need to open the software before Vmix. If not I receive an error message from windows.
JejeSwag tu déchires!
 1 user thanked gradateurFR for this useful post.
Quote:Impossible to open in my 2 vmix PC station... Marche très bien chez moi ! Works fine with me !
Sorry DAWN I modified my question during your answer ...
-->Works fine with me too (but need to open VRAC before VMIX)
Thanks Guy
Joined: 12/22/2020(UTC) Posts: 2  Location: Bioggio Thanks: 1 times
Hi!! I have try to download but was blocked by the Antivirus... "Virus detected"!!
Any reason?
Regards
Vrac is an homemade APP..... Your antivirus does not detect a virus but he don't saw a certification and he told you this.
2 personnes told you that the APP is functional. what else? ;-)
Have fun
I had scanned the file Vrac0.8 with the Defender. The file was automatically quarantined.Sorry in Deutsch.  Vrac0.8.jpg (68kb) downloaded 27 time(s).
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
There must be a problem with Windows Defender. I could not install VRAC or vmix on 2 computers. After forcing a Windows update, both programs went through without a hitch.
So, let Windows Update do a Defender update.
Originally Posted by: elvis55  I had scanned the file Vrac0.8 with the Defender. The file was automatically quarantined.Sorry in Deutsch.
It's strange, i tested on my side on two computers, i have scanned the file with defender and Endpoint antivirus and there is no threat. As said gradateurFR, window just says there is no certification, because it's a homemade app. otherwise, i see that a lot of people are interesed in my app, thank you, it will be with pleasure if my application can be useful in your projects ! :) if you have any questions or remarks, please share it with me, i intend to keep updating it to improve it !
I used it today for an event show.... IT was helpful for us.
We can speak together in MP (ou par telephone...) Because in use we have thought of small evolutions. Thanks again Tony
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
I try to download and then get this Error (404) We can't find the page you're looking for.
Joined: 2/14/2019(UTC) Posts: 11  Location: Texas Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Downloaded yesterday and testing today. So far, so good. Thanks for developing this!
 1 user thanked revned for this useful post.
Thank you very much everyone for your feedback, it gives me great pleasure that my program can help you in your projects! I just updated Vrac to version 0.9 ! Changelog : - Mute button, volume fader and routing are now linked to vmix - The routing window is now expandable, and the size of the input texts is larger - You can now change the size of the input fader, to display more fader on your screen - Vrac don't crash anymore when the connection is interupted - Added donation button, if you want to support this software ! Resize demoDownloadPlease feel free to contact me by pm or here if you have any requests!
 2 users thanked JejeSwag for this useful post.
USED 2 days ago for a big setup with multiple vmix unit. Work very very very well.
Thanks for the this great APP. GOOD idea to the donation button !!
Bonjour
Je suis intéressé par votre API par contre les deux liens semblent HS
Pouvez vous remettre l'API en téléchargement d'avance merci
Joined: 1/21/2021(UTC) Posts: 4  Location: Sydney Thanks: 2 times Was thanked: 5 time(s) in 2 post(s)
I like the program,
Could we post about it in the Facebook Group "vMix User Group & Training", would get alot more users.
Also it gets Flagged by windows defender detection still :( I'm able to install it, but would be amazing if it did not have that flag.
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
Still getting a 404 Error when I click on the link...
Maxi
Hello, sorry for the hs link, it's fixed now. I am currently working to create a version that does not trigger windows defender Originally Posted by: Craig99  I like the program,
Could we post about it in the Facebook Group "vMix User Group & Training", would get alot more users. yes you can share it no problem, preferably the forum link so that users will be notified of the next update and the download link will be dynamically updated, thank for you feedback ! :)
