Slay33D
#1 Posted : 11 years ago
Slay33D
On the Add Input menu, there is a check box at the bottom of the video tab that allows you to use videos with an alpha channel. However, there is no way to display transparency in videos if they are playing from the playlist. It would be very handy if it was possible to add this functionality.
Unless I missed something really obvious. That tends to happen. Please let me know if that's the case!
