lael
#1 Posted : Sunday, July 19, 2020 2:09:03 PM(UTC)
lael
OK, so we are building some 4RU vmix machines, but have struggled to get a case we like. I contacted a bunch of suppliers to find out what is on offer, and the answer... is not much. Well actually, lots that don't work well. But - one large manufacturer of cases decided to humour me, and voila, the 'perfect' 4RU case was born. It is designed to be short enough to fit into a plastic 19" deep Gator case / flightcase unit, and with a 240mm water cooling radiator at front, which gives total 3x120mm fans for good airflow.
The HDD caddy is a little bit of a compromise, but with nvme drives and SSD being our main hdd's, I don't think we/most people will actually use more than 2 3.5" drives. Orientation concerns shouldn't matter: https://blog.fosketts.ne...drives-side-even-upside/ And a little heat is ok, if not too much - https://static.googleuse...rchive/disk_failures.pdf
There is a PCIE card support for securing larger graphics cards during computer transit.
Anyway - I told the company I would post around and see if other people are interested in getting some. Let me know your thoughts / if you want one / some. I'm not selling them or making any money from this, just drumming up interest for a case I think we all want and need.
Images are available on Streaming Idiots on facebook:
[img]https://www.facebook.com/photo?fbid=10157611984286917&set=pcb.1468878489988047[/img]
PxlPht
#2 Posted : Saturday, August 8, 2020 11:41:46 PM(UTC)
PxlPht
Bahrain
I am looking around for a case that fits the gator
I am in for this
v0tti
#3 Posted : Saturday, August 15, 2020 11:16:06 PM(UTC)
v0tti
We are using the Genesys E420B 4RU in a Gator GRB-4U. Added two hot-swap HDD caddies to the case.
Only problem is that the case won't fit any normal sized GPUs. We are using a low-profile GTX 1050 Ti (there are also low-profile GTX 1650 variants available now).
lael
#4 Posted : Monday, December 14, 2020 4:10:30 PM(UTC)
lael
Ok, Well, the case is finally built! I'm getting some shipped to Australia, so let me know if you're interested.
Here are the photos: https://www.facebook.com...;set=pcb.516516935896968
