Broadcast 1080i and 1080p at the same time, is it possible?
Hello, is it possible to do this?
I need to output a signal in 1080i and another in 1080p at the same time
I need to broadcast in interlaced (1080i) for local television. For this I use custom RTMP Server putting the IP address of the server and the key, then, in external output I select vMix video / streaming and I put frame rate PAL 50i and Output size 1920x1080. With this configuration the broadcast is correct on television. But the problem comes when at the same time I need to stream that broadcast to YouTube. If in stream settings I choose the second tab and select youtube, the parameters are the same as those of the broadcast, so I cannot select progressive (1080p) and on youtube the signal is with little lines when there is movement.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
Use external out going to another software encoder like OBS or another instance of FFMPEG with your own settings
OR
Use an external hardware encoder on the PGM HDMI out
