Joined: 10/12/2020(UTC) Posts: 20  Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
I still have an issue where PowerPoint slides randomly go out of order when sending the 'Preview' to 'Output', especially when I have the Slideshow Settings window on secondary monitor! Any ideas?
Joined: 4/23/2017(UTC) Posts: 1,484  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Why don't you use the ppt as an input. vMix support the ppt file as an input. The other option is via NDI, online (present online, ingest as webpage) or a small program that provides a NDI signal from the loaded ppt.
Check that you haven't selected "Automatically Restart on Transition" in the Input general settings page. I turn all of the auto setting off for PPoints.
Originally Posted by: mavik  Why don't you use the ppt as an input. vMix support the ppt file as an input. The other option is via NDI, online (present online, ingest as webpage) or a small program that provides a NDI signal from the loaded ppt. I do use the PP as an input..., here's a mock up...  000142.png (516kb) downloaded 6 time(s).Tried Desktop Capture but it rendered terribly and I couldn't seem to hide the mouse cursor. I'll look at NDI
Originally Posted by: ask  Check that you haven't selected "Automatically Restart on Transition" in the Input general settings page. I turn all of the auto setting off for PPoints. Nope!  000141.png (28kb) downloaded 0 time(s).
