Hardware Compatibility
Issue with Elgato HD60 S+ Capture Device
I recently purchased the Elgato HD60 S+ capture device. I have tried to add it as a video source and it continually says the capture device is not supported. According to the website it says it is compatible with the software. I tried to add it into OBS to make sure everything was setup correctly and it was but vMix won't add it. Has anyone else run into this issue?
