Joined: 10/22/2016(UTC) Posts: 25   Location: Lucca, Italy Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Hello, the title mapping system for sports tables (results, rankings etc ...) is very long and difficult. I have to map row by row and column by column, and in the case of many championships the procedure is truly eternal. Is there the possibility of inserting a simpler and faster way to map sports tables in Vmix? Or is there an alternative system? I attached an example of soccer fixtures for better explain my situation.  Thank you very much and sorry for my English.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Match the title textbox names with that of the data source columns Then when linking the data to your data source select "apply to all fields"
This was a general question , not a feature request
Thank you... I try your solution!
My request is always an Easy solution for title mapping.
