2 Pages12>
#1 Posted : Thursday, December 10, 2020 5:19:52 AM(UTC)
Hi !
I'm using Mix inputs a lot and love it! However I think it would be great if we could define which inputs are available for them.
In fact, the only flaw of this feature is that the dropdowns get rapidly very long making it hard to select inputs. Besides most of the inputs can be totally irrelevant for use with Mix input. I just produced a show today where I had about 70 inputs listed but only needed around 15 to "sub-mix" with. Scrolling all these inputs to pick the right one is definitely counter-productive. Imho...
Why not add a tick box on inputs to set which inputs are to be made available for Mix inputs? Maybe in the "General" tab for quick access?
Maybe with a "settings" parameter where we could decide what is the default rule... Like "Always Add All Inputs to Mix Inputs" yes/no.
This way we could have more practical, more efficient dropdowns with a reduced number of entries...
What do you think guys? Like it? Add your +1 and carry on taking vMix to the Max !
TIA
Guillaume, aka DWAM
stigaard
#2 Posted : Thursday, December 10, 2020 5:24:59 AM(UTC)
stigaard
Views messages in topic : 492
Denmark
+1
thanks 1 user thanked stigaard for this useful post.
DWAM on 12/11/2020(UTC)
craig@craigburnett.com
#3 Posted : Thursday, December 10, 2020 5:35:16 AM(UTC)
+1
thanks 1 user thanked craig@craigburnett.com for this useful post.
rogerone
#4 Posted : Thursday, December 10, 2020 6:05:29 AM(UTC)
rogerone
+1
thanks 1 user thanked rogerone for this useful post.
NHT
#5 Posted : Thursday, December 10, 2020 6:10:25 AM(UTC)
NHT
+1
thanks 1 user thanked NHT for this useful post.
JimJacobs
#6 Posted : Thursday, December 10, 2020 6:19:06 PM(UTC)
JimJacobs
=1
thanks 1 user thanked JimJacobs for this useful post.
#7 Posted : Thursday, December 10, 2020 6:22:18 PM(UTC)
+1
monamiga
#8 Posted : Thursday, December 10, 2020 8:08:32 PM(UTC)
monamiga
Philippines
+1
thanks 1 user thanked monamiga for this useful post.
SamD03
#9 Posted : Thursday, December 10, 2020 11:05:34 PM(UTC)
SamD03
-1
I actually wouldn't want this - I don't think it's worthy of taking up valuable UI space and adding another option into the mix. If you're dealing with a show with this many inputs, you should honestly look towards setting up a dedicated control surface that could include managing your sub mixes. A streamdeck, Skaarhoj, or even built in vmix shortcuts are all valid ways you could operate the sub mix feature more effectively than the current drop down option.
thanks 1 user thanked SamD03 for this useful post.
stevespaw
#10 Posted : Friday, December 11, 2020 12:04:07 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
+1
Great Idea!
thanks 1 user thanked stevespaw for this useful post.
#11 Posted : Friday, December 11, 2020 2:44:11 AM(UTC)
@Sam Deans
Maybe I was not clear enough so let's try another way
- First, there is no space lost at all in the UI.
My suggestion is to add a global setting in the "settings" to set the default behaviour for Mix inputs. Point is to tell vMix which is your preference, like
> do you want your Mix Inputs dropdowns to be populated "by default" with all your projects inputs or only those that you select ?"
> I'd go for option "only those I select"
Then, in the "general tab" of each input, I'd like to see a tick box to set this particular input to be listed in the Mix inputs dropdowns.
This has absolutely no impact on the UI.
But, otoh, this would drastically impact the efficiency and the confort when using Mix inputs by not overloading the dropdowns with tons of inputs which will never be used through the Mix input. We would have immediate reading of the choice without scrolling to input 62 and back to input 5. Better ergonomics for better use! Live switching requires to be fast and precise, not risky and ambiguous !
- Second, I already extensively use shortcuts and control panels and softwares like UTC and Panel Builder to build my projects. I have around 100 shortcuts globally defined for common use + specific ones by projects. This is already too much ! We need to simplify and to make more flexible !
As a matter of fact, the reason why Mix inputs were implemented in vMix is to reduce the required number of inputs and shortcuts for sub switching within multiviews, PiPs and external outs.
See this post (which I believe started or contributed to the Mix input concept) : https://forums.vmix.com/....aspx?g=posts&t=8622
As is, the Mix input is close to being perfect: I think the only flaw is that the dropdowns are filled with too many entries which for the most part are totally irrelevant when you have set your use case for the Mix input.
- Don't get me wrong, shortcuts are great - as well as direct http/tcp requests to the API - but in some situations, they lack flexibility. I have use cases where I would need way more shortcuts than a control panel can handle and it takes a lot of time to set everything up and to memorize your setup. I know some guys produce produce the same show over and over. I don't. All my projects are different and it takes me days to set everything up sometimes for a 1 hour show... Sometimes I have to set shortcuts "just in case" I need them... or for a single operation on a several days production. It makes no sense to have a button on a control panel reserved for something that won't be used at all or for a one time keypress... That's stupid and that's when the Mix Input comes at the rescue !
- Still in this logic to try to reduce the number of shortcuts and to make vMix more flexible, I did this other Feature Request 2 or 3 years ago about Dynamic Inputs/Functions/Values. It's the same concern : less shortcuts for more operations.
My explanation ( https://forums.vmix.com/...-Functions-for-Shortcuts ) showed that shortcuts are not the solution to everything, especially not when for basic operations one needs to create 60 shortcuts to operate 6 inputs with 10 variations. Dynamic Inputs could reduce from 60 to 16 and that's a big deal, especially for control panels setups. Although it's been implemented in v24, I'm not sure it's ready for primetime yet > https://forums.vmix.com/...es-implementation-in-v24
This Feature Request here goes with the same concern. I love the Mix inputs but I feel it could be better, easier to use and more efficient if we could restrict the inputs to use with. It's just a slight enhancement to make it perfect !
Theavben
#12 Posted : Friday, December 11, 2020 7:28:53 AM(UTC)
Theavben
+1
thanks 1 user thanked Theavben for this useful post.
mburel1980
#13 Posted : Friday, December 11, 2020 6:52:59 PM(UTC)
mburel1980
Was thanked: 14 time(s) in 12 post(s)
+1
thanks 1 user thanked mburel1980 for this useful post.
clafarge
#14 Posted : Sunday, December 13, 2020 2:35:28 AM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
+1 (+9, but I don't think I carry that much weight)
thanks 1 user thanked clafarge for this useful post.
DWAM on 12/13/2020(UTC)
avsoundguy
#15 Posted : Sunday, December 13, 2020 9:54:08 AM(UTC)
avsoundguy
+1
thanks 1 user thanked avsoundguy for this useful post.
Radiotvpat1982
#16 Posted : Sunday, December 13, 2020 11:57:21 AM(UTC)
Radiotvpat1982
Was thanked: 15 time(s) in 11 post(s)
+1 Anything to clean up the "everything is an input" method is a great suggestion to me.
thanks 1 user thanked Radiotvpat1982 for this useful post.
topherharris
#17 Posted : Monday, December 14, 2020 3:36:47 AM(UTC)
topherharris
+1
thanks 1 user thanked topherharris for this useful post.
DWAM on 12/29/2020(UTC)
PTSinger
#18 Posted : Tuesday, December 29, 2020 9:04:41 AM(UTC)
PTSinger
+1
thanks 1 user thanked PTSinger for this useful post.
avsoundguy
#19 Posted : Friday, January 8, 2021 12:58:16 PM(UTC)
avsoundguy
+1
Ittaidv
#20 Posted : Wednesday, January 13, 2021 10:01:44 AM(UTC)
Ittaidv
+1. Would also love it to be able to select multiple inputs from the same category, and to add them all at once (HDMI inputs for example).
I'm vMixing professionally since 7 years now, and must have spent weeks, perhaps months clicking 'add input', selecting camera, selecting the dropdown, and than the right input out of a list that is too long. All those weeks or months, i could have used for holidays, for example :D
Guest (5)
2 Pages12>
