Problems with ShuttlePro v2 in vMix 24
Joined: 4/20/2017(UTC) Posts: 19 Location: Atlanta, GA
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
In vMix 24 I'm able to load the Shuttle Pro V2 template but none of the created shortcuts work. I can go back into the system and manually create the connections using the FIND option, but we would prefer to be able to use the template so we can quickly setup new sessions while using the Shuttle Pro V2.
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4727 time(s) in 1619 post(s)
We have updated the ShuttlePro v2 support in 24 to work with up to two shuttles at the same time, and thus they needed to be fully programmable with the shortcuts.
This means the button numbers have changed and we will update the built in template to reflect this prior to the final release.
Martin vMix
Thanks for the update, Martin. I look forward to the release when it's ready.
