3rd Party Software and Development
Very Easy Scripting Question - Text removal!
Joined: 10/21/2020(UTC) Posts: 17  Location: Bulkington Thanks: 5 times
So, all i'm trying to do is remove the first 5 characters from some text! I know that; Quote:CT1.remove(CT1.Length -5) will remove text from the end (CT1 being the variable), but I just can't figure out how to do it the other side! I've looked at VBScript help and tutorials (places like: www.w3schools.com), but cannot seem to get what should be an easy script to work :D any help is appreciated!
Joined: 12/27/2012(UTC) Posts: 5,442  Location: Belgium Thanks: 309 times Was thanked: 1002 time(s) in 828 post(s)
Do not look for vb examples but vb.net examples !
it's as a string to drop into a title
simple really, i just want to remote the "Call " from the callers, so I can just have their name!
I'll look for vb.net that may help me with other scripting issues :D
there is an example on how to get a caller name script in the "scripting for dummies" post !!
The helpfiles do specify it is vb.net !
also string.Substring(0, string.Length - 5))
Originally Posted by: doggy  Do not look for vb examples but vb.net examples ! Yep that helped a LOT!! haha sorted! Quote:CT2 = CT1.replace("Call ", "") I will tattoo vb.net onto my right arm lol!
