Joined: 12/7/2020(UTC) Posts: 15 Location: sussex Thanks: 1 times
I am having difficulty in getting the audio monitoring and paths that I want. Please can someone tell me what's wrong...
Inputs
x8 vmix call - routed to master , Bus A & B x1 ndi Laptop running microsoft teams - Routed to Bus A (client chat to vmix call) 1x Video, routed to Master (holding animation) 1x Laptop Mic, routed to Bus A & B (vmix and microsft teams talkback)
Video outputs
Master, Master audio Output 2, Bus A (Vmix Call) Output 3, Bus 3 (Microsoft teams)
Outputs are on and with corresponding audio output and all ndi functions on.
Audio Settings Master output- default windows playback Headphones - Headphones realtek R audio A - enabled B - enabled
My problem. I cant monitor any of the inputs without soloing them at the input or bus, unless I send them to the master. Then I can hear everything. I do not want to send some inputs to the master mix but still want to hear them. Can I make it so all audio can be heard if its toggled on. Unless I chose to have it not in the headphones. The problem comes when trying to listen to the vmix call and microsoft teams chat without broadcasting it? Any advice please.
Thanks: 3 times Was thanked: 10 time(s) in 10 post(s)
Hello. Go to Settings -> Audio Outputs. Select an output audio device for a BUS you want to monitor. Be sure to enable audio on that bus.
Just tested it out, it works. Added a music track to BUS A, and set output to headphones. Clicked a speaker icon on BUS A and heard the sound from headphones.
I have tried it out quickly and it seems to have sorted it. I had to re-assign the vmix calls audio setting afterwards. Im going to give it a full test later and see how I get on. Thanks. Knew it had to be something simple.
going on what you las said if I activate headphones for audio outputs A & B I lose bus b in the mixer completely.
If I put bus B on enabled then it comes back but only works if master is on.
After a play around the best setup appears to be
Master - enabled Headphones - Headphones realtek
A - Enabled B - Enabled
This mostly works how I want it to. If I so bus A then I can hear all the backchat outside master. If I un solo then I can hear the main mix.
Do I have the best solution to my inital setup?
You can try the following. Enable additional BUS C only for monitoring. Set headphones output only for this bus.
Add BUS A and BUS B as audio inputs in vMIX. Route them to monitor bus. Enable/disable routing if you need to hear 1 or more inputs.
