GT
Text dynamically align side by side
Joined: 9/27/2019(UTC) Posts: 49  Location: Kuressaare
Hi, how can I create dynamically text position so that two different text boxes do not go into each other. If the name is longer, it automatically goes into the text next to it, but in fact I would like the text next to it to move forward if the text above is longer.  pilt11.jpg (4kb) downloaded 10 time(s).
edit in title designer. lots of options there
(btw where you able to extend your trial ? )
Originally Posted by: doggy  edit in title designer. lots of options there
(btw where you able to extend your trial ? ) I have a license, Title designer not lot of options, I have asked in several forums, but so far there is no answer on how to do it.
Because it is not possible fully that is , you could sort of do it if the right textbox text is of fixed length end right aligned crop/mask it to the left textbox and move the bounding to the right past end of textbox 1 like here right text crop/masked to underlying left textbox/rectangle
Originally Posted by: doggy  Because it is not possible fully that is , you could sort of do it if the right textbox text is of fixed length end right aligned crop/mask it to the left textbox and move the bounding to the right past end of textbox 1 like here right text crop/masked to underlying left textbox/rectangle Can you make a .gtzip file where the two names are next to each other and work so that I can figure out how to do such a thing?
Originally Posted by: doggy  This working correctly with background, but if I use two textblock, that's not working for me
Quote: text is of fixed length end right aligned crop/mask it to the left textbox and move the bounding to the right past end of textbox 1
Joined: 5/19/2018(UTC) Posts: 12 Location: Faroe Islands/Poland
Was thanked: 8 time(s) in 4 post(s)
Hi This seems a bit like what I have been a bit stuck with now. Trying to do name presentation, where first name is regular text, and lastname is bold text. firstname LASTNAME , and lastname must be dynamically positioned to the firstname length.  Capture.JPG (22kb) downloaded 50 time(s).See attached picture. It is ok to create a textfield for firstname and another for lastname, but lenght of names is vary dynamic, and will not work. Any one know how to do this in GT titler?
One can not but can with a legacy XAML titles
GT
