Joined: 12/7/2020(UTC) Posts: 3  Location: Lancaster, NY
When creating a text slide, is there a way to make the background transparent; so it can be seen over a live camera shot?
Joined: 12/7/2020(UTC) Posts: 1  Location: Kansas City
Originally Posted by: pompeiisafe2020  When creating a text slide, is there a way to make the background transparent; so it can be seen over a live camera shot? Go to Insert > Text Box and drag a text box over your image. Right-click on the text and select Format Text Effects. Go to Text Fill and select Solid Fill. Adjust the transparency slider as needed.
In version 23.00.66, I do not see a choice for insert. Am I missing it?
