vMix Call
Get the short url for the caller
Joined: 3/26/2020(UTC) Posts: 23   Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
I know when you create a vMix call, a short URL is created, for example https://vmix.at/#####After I create that call, how can I get that URL, AFTER it's created? I know I cal right-click on the call, open up Call Manager and search for the password...but is there a way to get the short url? Thanks.
 1 user thanked tcconway for this useful post.
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
I don't think so, but it would be helpful for sure.
The "encoding" ist decimal (base10) to a specific alphabet (base62): Alphabet is "0123456789abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ" (62 chars). See https://sig11.de/vmix/ for a working javascript implementation. Save that page locally and use as needed :-) Another way: Save the preset and restart vmix, in the callmanager log you will see the vmix.at/... URL's
Joined: 12/16/2019(UTC) Posts: 87  Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
vMix Call
