kclark
#1 Posted : Sunday, December 6, 2020 10:59:27 AM(UTC)
kclark
I have images that I use that have static messages like "Thank you for joining us, the service will begin shortly." In Wirecast, I was able to attach audio files to the intro and outro's and they would loop as well as the intro would show for 10 minutes prior to the live event. How can this be done in vMix? I have 3 audio files that I would like to use to try to fill up the 10 minutes and loop if necessary.
#2 Posted : Sunday, December 6, 2020 11:03:57 AM(UTC)
Create a list input with your audio files and use the list options to set it to play as you wish (loop, autoplay, etc...)
Create a photo input with your staic images and set it to play as you wish
Add this list input as a multiview layer to your photo input
Send your photo input to PGM > it plays the music
You're done!
kclark
#3 Posted : Sunday, December 6, 2020 11:21:48 AM(UTC)
kclark
You're done!
Well that just went over my head...I'm going to have to study this. I like vMIx but this part was much simpler in Wirecast. I guess there is a bigger learning curve than I was anticipating.
#4 Posted : Sunday, December 6, 2020 6:35:42 PM(UTC)
There's nothing complicated here, vMix offers so much more than Wirecast ! In every terms ! So yes there is a learning curve and you will realize soon that, unlike competitors, there are very often multiple ways to achieve actions with vMix because it is so "flex-able". A blessing for creative people !
