MarkNF82
#1 Posted : Sunday, December 6, 2020 2:20:24 AM(UTC)
MarkNF82
Canada
Was thanked: 6 time(s) in 4 post(s)
Hello vMix,
A few times now I have been wanting to crossfade between titles on the same layer, either to a different preset of the same title, or a completely different title. In doing so, vMix transitions the first title out completely then immediately transitions the next title in. Because of this, using a "fade" transition, results in one title fading out completely, then the next title fading in and not a smooth crossfade to the next title.
As I only have vMix HD, I cannot build animations for GT Titles so I can only assume this can be accomplished with an animation for a "datachange" value, however I am not certain. This however would also require a datasource be created I assume, which seems to be overkill if only using 2 or 3 titles.
If there is a way to do this currently, could someone please explain, if not I would like to have this feature added. It seems simple enough to implement I would think.
#2 Posted : Sunday, December 6, 2020 2:50:27 AM(UTC)
Don't know if the HD license has it but you could try a MIX input
Bit if there is s need for more functionality and option an upgrade might need to be considered
mavik
#3 Posted : Monday, December 7, 2020 6:05:09 AM(UTC)
mavik
Have you tried a merge transition.
