Feature Requests
Shortcuts: PreviewInput/VirtualSet/Slideshow Settings
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
1. PreviewInput:
I already made a post about shortcuts to put videos from a list directly to the output. The solution was a simple cut transition to that specfic video instead of ListPlayOut.
But now I would like to put specific videos to the preview window and make the normal transition when it's time to do it, but the PreviewInput shortcut doesn't seem to work with video selection, even if there is the option to choose a video.
2.VirtualSet:
Is there a shortcut to go to one of the 4 preconfigured virtual set windows? If so, please tell me the name of it. if not, then a new shortcut for this would be great too!
3. Slideshow Settings:
I would also like to have a shortcut to open the slidehow settings and maybe even other stuff like title editor window or input settings windows.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: Rinsky
2.VirtualSet:
https://www.vmix.com/kno...s-angles-using-shortcuts
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
But now I would like to put specific videos to the preview window and make the normal transition when it's time to do it, but the PreviewInput shortcut doesn't seem to work with video selection, even if there is the option to choose a video. Actually, the solution is kind of the same as for the Virtual set shortcuts: Also use the SelectIndex shortcut on the same button as the PreviewInput shortcut.
Feature Requests
