Joined: 12/3/2020(UTC) Posts: 2  Location: Aartselaar
Hi.
We build alot of vmix systems for clients of us. And we also use them ourself for our own productions.
We are wondering if there is a way to update the stream key and url in a vmix system remote. What i mean by that is. For some of our customers, we install a vmix for them and then control the entire vmix system by api with a Qsys system. This makes it very easy for the customer to use the system without them having knowledge about the vmix system. The only thing we cant control at the moment and where we have to have the customer go into the vmix interface. Is if they have to update the stream key and url.
Does anybody know of a way to fill in this data from a remote place? like we can build a local website that updates the information in the vmix. Or with the API? so customers don't need to go in the vmix and possible get lost and change settings.
Greets, any help is welcome.
Robin
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
usefull ?? van enig nut ?  streamkey.JPG (58kb) downloaded 1 time(s).
Thanks,
I did not notice this before. We will give this a try.
I don't know how we missed this.
Dank je wel.
