Virtual Sets - where to buy?
Joined: 10/24/2020(UTC) Posts: 25  Location: Virum Thanks: 10 times
I'm a newbie in virtual sets. I have to etablish a vistual sets, which can handle approx 6 people in a panel discussion. I have looked at a number of suppliers, but some home pages seems to be in a better quality than others. Is there a difference quality and can some of recommend certain specific shops to buy from?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
If you mean the usual virtual set with bordered windows and not a green screen setup, there is already one premade in the Virtual set templates. Or you can create your own pretty easily.
I'm thinking on green screen setups with studio designs :-)
Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Not sure if this is any good for you but have you looked at Videohive for virtual sets? You will need After Effects (AF) but you can always export a screen from the AE timeline and import into vMix. They do great intros, graphics, lowerthirds etc. It can really transform how your production looks, but as I said you will AF. https://videohive.net/ca...iles?term=virtual%20sets
 1 user thanked Simsyuk for this useful post.
