Feature Requests
NEW Activator Event "StreamingWarning"
Joined: 10/25/2018(UTC) Posts: 43  Location: Moscow Thanks: 8 times Was thanked: 4 time(s) in 3 post(s)
Please add a new event for activators. The event should be executed when the " stream" button is at the bottom and the sign at the top turns orange (when something goes wrong with the stream). When the stream returns to " red", the old "streaming" activator must be executed again. This is convenient when, in case of problems with the stream, a separate indicator on the external controller will light up  streamwarningrequest.jpg (178kb) downloaded 0 time(s).
My custom controller also supports blinking when "velocity" = 2, so I'd really like to. so that during a normal stream, the button just burned, and in case of problems it began to blink. And when the problems disappeared - again with the "velocity" = 1 it started to burn normally.  2020-11-09 00-35-50.JPG (418kb) downloaded 0 time(s). 2020-11-09 00-35-34.JPG (428kb) downloaded 2 time(s).
Feature Requests
