Is there any way to trigger other commands using the same key in Panel Builder. An example would be playing an audio clip when a score is increased? I can do this with the streamdeck, by assigning the same key to a different shortcut. I know there are different ways to do this, but I'm trying to keep the programing of an event as simple as possible. I love the software by the way.
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Hi Studiorove,
You can do this 2 differrent ways.
1. If you only have two commands within a button, you can assign one command to the "Dn" position and the other command to the "Up" position. 2. You can create a "Script" within a button by using the Script> ScriptDynamic command and add as many command as needed. Note: Scripts only work with vMIx 4k or Pro.
It's good practice to keep questions related to an app in the same thread... please use the "vMix Panel Builder" thread for questions related to the app. It can often help other users monitoring the thread :)
thanks, Richard
Thanks for this info. Sorry I thought I posted it in the Panel Builder thread, but I must have created the post incorrectly.
