StryderTV
#1 Posted : Thursday, January 30, 2020 2:51:06 AM(UTC)
StryderTV
Is there a way of monitoring the audio whilst shuttling the in and out points. I will give an example. You are doing a football post match interview with a manager so you set an approximate in point and after its over you set an out point. You now go back to the interview and shuttle the in point to get a good start point but there is no audio to monitor to find where the start of the first question is. Similarly you want to set an out point.
Am I missing a setting to enable this please?
#2 Posted : Sunday, February 2, 2020 3:24:30 AM(UTC)
@ StryderTV
You should be able to use the "Solo" [S] button in the vMix Audio Mixer for the RepLay A Input.
If you click the Instant Replay play button and scrub through the time line while "Solo'd" (but not LIVE) you will hear the audio on the PC's Speakers/Headphones.
StryderTV
#3 Posted : Sunday, February 2, 2020 7:08:26 AM(UTC)
StryderTV
Thanks Ice
I will try that, I hadn’t tried taking it out of Live. I will get back to you.
StryderTV
#4 Posted : Thursday, November 26, 2020 8:48:37 PM(UTC)
StryderTV
Many thanks IceStream for your input.
This only works at normal speed, what I am trying to achieve is the ability to hear the audio as you are scrubbing up and down the timeline, similar to what you would be able to hear in editing software? I just need to be able to hear the first and last words of an interview on the fly.
I have tried sending the audio to another output (A-G) but can't get it to work, any work arounds anyone can think of?
Similar Topics
Monitoring audio whilst shuttling in Replay (Feature Requests)
by StryderTV 2/2/2020 1:53:26 AM(UTC)
