Joined: 3/3/2019(UTC) Posts: 9   Location: Brasília Thanks: 1 times
Hi guys!
Does a Notebook with a Quadro RTX 3000 has a good performance for Vmix over a Laptop with 2070? I just bought a i7 9850H with Quadro RTX 3000, 64GB of RAM and 2TB nvme m.2 SSD.
Does it has no limits for encoding with this GPU?
Thank you!
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Hi Mjgraves.
Tnx for your answer. I know this table. My question is about Max # of concurrent sessions. Geforce Series has a limitation of 3 concurrent sessions and RTX has no limits of max # of concurrent sessions. The GPU is a Quadro RTX 3000 allow 1 NVENC but my question is about the "unrestricted" info.
Originally Posted by: kardellivemedia  Hi Mjgraves.
Tnx for your answer. I know this table. My question is about Max # of concurrent sessions. Geforce Series has a limitation of 3 concurrent sessions and RTX has no limits of max # of concurrent sessions. The GPU is a Quadro RTX 3000 allow 1 NVENC but my question is about the "unrestricted" info. The confusing thing is the terminology. They say "GeForce RTX" and "Quadro RTX." There's only one physical encoder in either case. It can do 3 streams (sessions) on the RTX. Unlimited on the Quadro. The real limit on the Quadro is the capability of the silicon. It can do many, many low-res streams. Fewer high-res streams.
Joined: 2/9/2013(UTC) Posts: 264 Location: Katy, Texas
Just ordered a similar laptop at a great price. I'll find out what its capable of in a couple of weeks.
