thsorensen1
#1 Posted : Saturday, February 15, 2020 9:02:53 AM(UTC)
thsorensen1
Norway
Was thanked: 3 time(s) in 1 post(s)
So, with the new version of vMix with 8 audio channels (A-G + M) we can now do a lot more with audio.
I'm currently setting up a vMix solution for a bigger production with communication with MIXMINUS for producers and reporteres integrated in vMix.
The show will need all of the output channels for this event (multiple reporters and photographers), and everything needs to be controlled dynamically.
I'm using a Focusrite 18i20 USB sounddevice for all the audio outputs.
The concept is a webpage that controls all of the output channels, you can route all input audio sources to the outputs(A-G + M).
See this video how this is working when in use:
In use video
To do this smoothly I have created a small web application that polls the vMix API (http://127.0.0.1:8088/API) every 300MS, and parses the XML.
The code is currently NOT documented at all and is only a PoC, I will do some more work on this in the next couple of weeks.
Every input source is added manually in the source body.
To run this app, you will need to rename the file to e.g. vmatrix.html, and run it on a local webserver.
vmatrix.txt (9kb) downloaded 107 time(s).
thanks 3 users thanked thsorensen1 for this useful post.
dmwkr on 4/16/2020(UTC), avsoundguy on 4/27/2020(UTC), stigaard on 4/30/2020(UTC)
stigaard
#2 Posted : Wednesday, April 15, 2020 10:45:46 PM(UTC)
stigaard
Denmark
Good job. Cool stuff in simple app. Well done.
avsoundguy
#3 Posted : Wednesday, April 29, 2020 4:31:16 AM(UTC)
avsoundguy
Not getting the app to run, just get a page with a "Start update" button in the upper left corner
stigaard
#4 Posted : Thursday, April 30, 2020 6:35:49 AM(UTC)
stigaard
Denmark
I made a electron version of this. Try downloading this app: https://github.com/jenss...x-vmix-electron/releases
Looks something like this:
Audio Matrix vMix App Electron
thanks 4 users thanked stigaard for this useful post.
ask on 4/30/2020(UTC), Video Dave on 4/30/2020(UTC), desmar on 4/30/2020(UTC), BRebels on 11/23/2020(UTC)
dark_ata
#5 Posted : Saturday, May 2, 2020 4:05:43 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
very interesting, also now i feel stupid in febrary i used all the channels and i maldi the UI thinking that not have any way to check if one audio is in C-G channels , right click ...
BRebels
#6 Posted : Monday, November 23, 2020 10:30:54 PM(UTC)
BRebels
stigaard having an issue using your app on OSX 10.15.7
Pop-up window says "The application "Audio Matrix vMix Electron cant be opened".
Will it not run on Catalina?
stigaard
#7 Posted : Tuesday, November 24, 2020 8:48:37 AM(UTC)
stigaard
Denmark
I will take a look at the issue tomorrow.. Perhaps something to do with code signing..
stigaard
#8 Posted : Thursday, November 26, 2020 4:03:05 PM(UTC)
stigaard
Denmark
The issue is now fixed.
thanks 1 user thanked stigaard for this useful post.
BRebels on 12/4/2020(UTC)
jip
#9 Posted : Sunday, August 1, 2021 12:08:10 AM(UTC)
jip
Estonia
thanks for the convenient matrix app.
I would propose few small updates:
1) for buses A-G, there could be a button for routing bus to Master (like M button in vMix audio mixer)
2) get default bus titles from vMix api (buses can now be renamed in vMix)
3) solo buttons for buses and inputs
Could these be implemented? I guess the last one is the most demanding.
thsorensen1
#10 Posted : Friday, August 20, 2021 5:31:24 PM(UTC)
thsorensen1
Norway
Hi.
Sorry for late response here.
I'm sorry to let you know that I'm not able to do these features as I currently not using this system my self.
However, the features you are asking for should be easy to fix if you get someone with basic javascript experience.
Best of luck..!
Thomas Sorensen
sean.norris
#11 Posted : Wednesday, September 29, 2021 7:48:52 AM(UTC)
sean.norris
This is really cool! Thank you
