Roy Sinclair
#1 Posted : Monday, November 23, 2020 3:49:44 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Than you very much for adding more audio channels but of course that comes at the price of us asking for ways to use those.
By allowing us to select one of those audio channels to be broadcast to the web pages for tally and mixing it would make it possible to use standard earbuds off of tablets or smartphones and inexpensive wireless beltpack mics to create a very easy way to allow a person acting as a director to communicate to camera operators, lighting controller and/or stage hands.
The mics wouldn't need to be broadcast quality since the audio would be internal use only and pretty much everyone has a smartphone or tablet these days.
Our Church already has an inexpensive set of beltpack mics that we normally only use for children's programs plus a few more older beltpack mics that still work but were replaced for higher quality ones.
So we already have the hardware that could be used to make an active director system except the USB interface to add one more audio feed into the vMix program and of course the ability to send that channel of audio through the web interface.
Paul Fuhrmann
#2 Posted : Monday, November 23, 2020 4:26:00 AM(UTC)
Paul Fuhrmann
Germany
Was thanked: 9 time(s) in 8 post(s)
Hey Roy,
iam a bit confused what you want. Because it is a bit confusing to read.
You have a lot of wireless mics. ANd you want something like a intercom talkback that the director (who is using the web controller) can speak to tha camera operators.
Normaly you use intercom systems from RTS or Clearcom to crate a partyline where all teammates con talk to each other.
You can do it with vMix but it is not an good idea to do because of latency. (Usually you hear yourself on the intercom [sidetone/selfmonitoring] but ech tiny ammount of delay make you feel uncomftable and vMix behaves like an software DAW wich had latency and latency is not good for communication.
If i read correctly you want the director talk over the webcontroller tabblet wich is a voip service (more delay)
So an analog mixing desk and or a headphone preamp or headphone beltbacks is the only stuff you will need.
if you are are more into digitaul stuff make an teamspeak server and let all personnel use thier mobile
Roy Sinclair
#3 Posted : Monday, November 23, 2020 4:45:25 AM(UTC)
Roy Sinclair
The point is that we already have the equipment to make an "intercom" system without buying a whole new system from someone else if we can have one of the vMix audio channels fed out through the web interface that's already used for tally indicators to our camera people who are using their phones right now to know when their camera is live or preview.
This means we wouldn't have to shell out thousands of dollars just to have a rudimentary intercom system that would be perfectly satisfactory for our needs.
mavik
#4 Posted : Monday, November 23, 2020 5:31:33 AM(UTC)
mavik
There are apps on mobiles that act like aan inntercom. Zello is just one to mention. Some phones and apps can be run in split screen. You can have one half for tally and the other for intercom. VLC is able to play SRT streams. You can use that to connect to vmix audio.
Roy Sinclair on 11/23/2020(UTC)
Roy Sinclair
#5 Posted : Monday, November 23, 2020 5:37:55 AM(UTC)
Roy Sinclair
Thanks, I'll check that out. If it works then it would not need to be added to vMix and would be one less piece of equipment to wear as well.
Paul Fuhrmann
#6 Posted : Monday, November 23, 2020 6:12:44 AM(UTC)
Paul Fuhrmann
Germany
So hearing the director is easy with mobiles.
Just send the directors voice to an bus and make an ndi output (you can also send audio inputs per ndi directly)
The cameramen can use a ndi minotor app to listen to him but talking is a bit more complicated.
Be aware that intercom (selfbuild is tricky) is not that easy as you think. Iam not aware if vMix can do a mix minus with audio inputs (like calls do)
So if camera A speaks to direktor and camera B and C and you will lead in hearing him hisself with the delay in vmix wich makes him stutter (i tested this)
To make it good you need one audio bus for each intercom listner and send cam a to output directo cam b and cam c. Cam b sends to cam a and cam c and director and so forth.
The sidetone most be generatet at the taliking side.
You will also need an audio interface with a lot of outputs
The most of the stuff you have is the analog mic and headphone gear. Now you will need a fast mixer. Even a better digital audion interface could be the soultion if it comes with an dsp an independed latency free headphone mixes. But the roundtrip throug the pc will make most people stutter.
Like mavik soid use other apps:
https://www.unityintercom.com or teamspeak, or a zoomcall.
Please make notice that avery streamed audio is useless when you need a sturdy timebase. every network based streming solution will couse timing trouble.
If the dirctor makes on countdown and all need to da specific task in the same moment get sure they hear the command the same time (wich is not possible allways possible)
