Originally Posted by: elgarf  @amir, is this just a number of seconds or something with colons, like mm:ss? uumm I'm using timer widget (ss) , the default time on 24 second reverse , and I need when the timer under 5 second , the orange image is visible and else it invisible that orange image .. Is it possible?? like this  Untitled1.png (8kb) downloaded 7 time(s).
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@amir29918, replace @number="2" and @index="0" with your input number ant text indexes. Is used to convert string result of xpath function to numeric value. Then this value compared to 5. You can also use @key="{0}" (set input 1 parameter to your title) instead of @number="2". Code:>Condition(, , xpath('vmix/inputs/input[@number="2"]/text[@index="0"]') * 1, <, 5)
>*SetXVisibleOn(, 0, Image)
>*Else()
>*SetXVisibleOff(, 0, Image)
>ConditionEnd()
>Timer(500)
>GoTo(0)
Logic is: Code:if value in title < 5 then
show image
else
hide image
wait 500msec
repeat from beginning
 1 user thanked elgarf for this useful post.
Joined: 3/28/2020(UTC) Posts: 4  Location: Madrid Thanks: 1 times
First, thank you for this excellent application and secondly apologize for my horrible English, I hope I can explain correctly.
I am trying to make a script so that depending on the signal in the program or preview it executes a script or another.
Something like:
If activeinput == input 1 (or previewInput == 1) script 1 Else script 2
Well I am not able to do this condition, I have tried things like:
Condition (,, activeInput, ==, Input 1) Condition (,, -1, ==, Input 1) Condition (,, Input 1, ==, -1)
or with the data from Dummy function (Ctrl +Space).
Can anybody help me?
I answer myself, it is as easy as.
Condition (,, xpath ('vmix / active'), ==, 1)
It is possible that it can be done in a more elegant way but that is how it works.
Thank you
@cocalo, that's the right way) There also is _ function to access internal UTC state:
_('Active')
Rank:: Member
I'm trying to make a title animation appear when the play clock on my scoreboard gets to 00. I'm not sure if I'm doing something wrong in the scripting in the button widget or if it's even possible with utc. Can someone please help?
Joined: 9/27/2020(UTC) Posts: 4  Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: cashmuny03  I'm trying to make a title animation appear when the play clock on my scoreboard gets to 00. I'm not sure if I'm doing something wrong in the scripting in the button widget or if it's even possible with utc. Can someone please help?  Condition _('Inputs[{0}].Elements[0].Text') == 00:00 No. of element that time/text You looking for is in http://192.168.0.171:8088/api/
I have a same issue . I want to when timer on 3:00 , timer is pause . I set a link for pause and put it on condition but not working..  Capture.PNG (50kb) downloaded 10 time(s).
Because Inputs in {} brackets refer to intput 1 and 2 which You can choose in Condition constuctor. But as everything in UTC - 1st input is Input[{0}] and 2nd [{1}]. So i Sugest to change that {2} for {0}. Or You can try to add 2nd timer which starts in synq with the 1st one, and just set 2nd to stop at 3:00 and on competition send Execlink command that stops 1st clock
 1 user thanked pykawka for this useful post.
Rank:: Member
Thanks for the responses. I'm now having an issue where it appears utc doesn't recognize 00 as 00 but instead as just 0. i've tried 0, :00 & 00:00 and none work. What can I do to make 00 = 00?
This is what the code says. I have run a clock in vmix from 05 down to 00 and nothing happens
*Condition(a744a0f9-e657-40e3-a228-fa58c2cf797b, 5820bab3-fe56-4539-8dbb-5b3a057d0823, _('Inputs[{0}].Elements[16].Text'), ==, 00) *TitleBeginAnimation(a744a0f9-e657-40e3-a228-fa58c2cf797b, Page2) !*Else() !*SetXVisibleOff(a744a0f9-e657-40e3-a228-fa58c2cf797b, 17, Text) *ConditionEnd() !*Timer(10000) *GoTo(0)
This is the log
7) GOTO 0 [0] CONDITION CHECK 00==0
Did You check "State dependent" on that .gtzip that you refer in Your condition?
Rank:: Member
Yes "State Dependent" is checked
Originally Posted by: cashmuny03  Thanks for the responses. I'm now having an issue where it appears utc doesn't recognize 00 as 00 but instead as just 0. i've tried 0, :00 & 00:00 and none work. What can I do to make 00 = 00?
This is the log
7) GOTO 0 [0] CONDITION CHECK 00==0 Hi @cashmuny03 Replace this code in the first Line Code:Condition(, , xpath('vmix/inputs/input[@number="0"]/text[@index="16"]') * 1, ==, 0)
@cashmuny03, 00 is transformed to 0 (because it is treated as integer). If you want to compare strings, write '00' instead. Or use @amir29918 tip to make numeric value from your left part of condition.
Rank:: Member
Thank you Amir and elgarf for trying to help me. I don't know what I'm doing wrong still. Here's what I've tried.
Condition(cc609620-2644-410f-ab81-13f213af2c12, , xpath('vmix/inputs/input[@number="0"]/text[@index="16"] * 1, ==, 0)
and I've also tried
Unfortunately neither of these work. elgarf, you said "write 00 instead". Where do I write 00? Sorry this is so confusing
Joined: 10/5/2020(UTC) Posts: 2  Location: QC Thanks: 2 times
Hi , Trying to figure out the how to set a condition based on text Here the code to change my text to Green: Quote:*SetText(8123a224-92ec-4a1b-9bf6-688c8b0aba8b, 0, Green) And i'm trying to figure out the code for if text is green then do some action ? Here is one of my try but I always get a Condition is False return : Quote:*Condition(, , Inputs[8123a224-92ec-4a1b-9bf6-688c8b0aba8b].Elements[InputText/Index/0].Text, ==, Green) I have it running inside vmix script with this code : Quote:If Input.Find("var1.xaml").Text("Headline") = "Green" then "do action" My var1.xaml is input #42 if that can help Thanks a lot if someone can help me !
Joined: 7/19/2017(UTC) Posts: 45  Thanks: 11 times Was thanked: 14 time(s) in 7 post(s)
Weird bug today Elgarf. I was editing a layout, when suddenly I lost the ability to change the title map on my list items. I could still change the input, and it would update in vMix but I couldn't find the title mapping option in the list item window at all.
Saved, quit and reloaded and it worked again, but strange bug. Caused a minor stroke.
@cashmuny03, I mean you need use single quotes to compare two strings. Like that Code:*Condition(a744a0f9-e657-40e3-a228-fa58c2cf797b, 5820bab3-fe56-4539-8dbb-5b3a057d0823, xpath('vmix/inputs/input[@key="{0}"]/text[@index="16"]'), ==, '00')
@PLandry26 Try using Code:*Condition(, , _('Inputs[8123a224-92ec-4a1b-9bf6-688c8b0aba8b].Elements[InputText/Index/0].Text'), ==, Green)
or Code:*Condition(, , xpath('vmix/inputs/input[@key="8123a224-92ec-4a1b-9bf6-688c8b0aba8b"]/text[@index="0"]'), ==, Green)
You need to use request function _(path) or xpath(path) to get value from vMix state. @NewsworthyVision, looks like it's connected with volume widget. I'll make fix later.
Joined: 11/25/2020(UTC) Posts: 1  Location: Obrenovac
Is there anyway how I can dynamicly change image in my title?
Hi guys
Another question for that forum. I use the score widget. I try to trigger a sound each time i increase the score. But there no way to add code or use the constructor mode with that widget. How i can make that happen ?
thanks
