Issues with sources on same resolution than output size
Hello, For no apparent reason, when I set a source (video file, NDI, ...) with the same resolution as the output size of my vmix project, the source is glitching, like if there were an interlacing problem or something, but all my sources and my project are in progressive framerate ... For example, if I set the output size in 1920*1080, and import a file or set a NDI source in 1920*1080 or higher, a glitch happen (see the picture, my video source is 1920*1080), but il I ad a source in 1280*720 it works perfectly ! Same if I set the output size in 3840*1920, a 1920*1080 source will work well, but a source in 3840*1920 or higher will glitch ... I can't understand the problem .. Does it come from my computer or is it a vMix issue ? I'm on Windows 10 with a NVIDIA GEFORCE GTX 1050Thanks you !  Sans titre.png (364kb) downloaded 1 time(s).
Thank you it works !
Sorry I didn't saw this topic in the FAQ !
Have a nice day !
