Hi Martin
I'am testing VMIX 12 having the following hrdware
Win 7.0 64bit CPU XEON 6core 12 with HT DATAPATH Vision 4+1 for Four SD input Declink Studio for output 32 Gb Mem Nvidia GT 640 Video card
This is tha issue.
I set inputs on each of four inputs of Datapath saving all to preset file When i restart vmix all setup done on Dathpath go lost and have to reset everything.
Can you suggest any. Thanks Ludovico
Ludovico, try clicking on Last Preset, or Open Preset. vMix opens in an empty profile by default unlike some other software.
I will try with Last Preset with open preset the same.
I just want remark only DATAPATH settings get lost.
Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
You may need to contact Datapath about that. If the settings are in the datapath settings window then vMix is not able to save these in the preset as they are not made available to the program.
Martin vMix
