Bikeroo
#1 Posted : Tuesday, November 17, 2020 12:40:01 AM(UTC)
Bikeroo
Poland
So far I making a lot of calls from MS Teams through NDI input.
All worked well since today.
I don't know why, but now I can't see NDI input from MS Teams in vMix anymore.
I made all steps all always:
- enable NDI inputs in vMix settings
- enable NDI in NewTeck NDI Virtual Input
- enable NDI in Teams permissions
- choose right audio/video source in Teams settings
I made it a lot of times before but today it dosen't work any more and I not see Teams windows in vMix NDI inputs.
Anyone have simillar problem? Maybe something with Windows update or AntiVirus?
I have no idea, what cause this problem :(
Pepsi(~)
#2 Posted : Tuesday, November 17, 2020 3:36:38 AM(UTC)
Pepsi(~)
Netherlands
There is a new option that you must select during a call.
The Enable NDI in the permissions is something you need to select before the call.
MS build in 1 additional step that by default NDI will not broadcasted on your local network.
During a call click on the 3 dot’s. And than (out of my head) selected NDI Broadcast.
Once you have selected that the NDI broadcast will start on your local network
Or someone has enabled the firewalls on your systems. Or disabled multicast on your local network
Bikeroo
#3 Posted : Saturday, November 21, 2020 7:26:27 AM(UTC)
Bikeroo
Poland
Thank you so much for help @Pepsi!
That was exactly what you wrote.
Just one more step in MS Teams.
Problem solved.
Thank You :-)
