2 Pages12>
Dweyq
#1 Posted : Monday, November 16, 2020 3:08:22 AM(UTC)
Dweyq
I was really cheerful to have found my way of configurating my apc mini when I realised there was no AudioAuto activator.
It would be really helpful to have this option incorporated in the future. ;)
xemles
#2 Posted : Tuesday, November 17, 2020 9:27:50 AM(UTC)
xemles
France, Metropolitan
Not sure to understand, I'm pretty sure it's available already. Where are you looking for it exactly?
_____________
J'ai vu le drapeau français donc je me permets de la refaire en Français:
Je vois pourtant dans la liste de l'API l'AudioAuto de disponible...
Où le cherches-tu exactement?
Dweyq
#3 Posted : Tuesday, November 17, 2020 5:38:10 PM(UTC)
Dweyq
Sure, the shotcut does exist but not the "activator" for the colors of the controler's buttons.
Le raccourci pour contrôler l'activation/désactivation existe effectivement, mais pas "l'activateur" qui permet d'assigner une couleur spécifique au bouton de l'apc (ou de n'importe quel autre contrôleur) en fonction de l'état on ou off de l'AudioAuto.
#4 Posted : Tuesday, November 17, 2020 6:32:14 PM(UTC)
Salut
avant de poser des feature requests, il est bon de s'assurer au préalable qu'elle soit absolument justifiée, ce qui n'est pas le cas en l'occurrence. Tu aurais donc dû commencer par poser ta question dans la section "générale" où on t'aurait répondu :
Activator: InputAudio
Before submitting unjustified feature requests, please make sure, absolutely sure, that what you're asking for does not already exist in vMix by checking the manual, the Knowledge Base, the countless vMix tutorial videos on YouTube and finally using the General section on this forum to expose what your issue is. If it turns out there is absolutely no solution available then you can submit a Feature Request.
In this case, the answer is "use the InputAudio" activator, making this Feature Request totally irrelevant.
Dweyq
#5 Posted : Wednesday, November 18, 2020 2:17:12 AM(UTC)
Dweyq
J'ai justement cherché partout, épluché tout ce que je trouvais sur le sujet. J'ai effectivement omis de poser la question avant de demander cette feature request, ce que je vais faire immédiatement.
Par contre, la réponse n'est pas InputAudio.
Cet activateur agit en fonction du mute de la piste, pas de l'audio follow.
I actually have researched it, I've read and seen all I could find on the subject.
I did forget to ask before submitting this request, which I will do right away.
Nevertheless the answer is not InputAudio.
This activator works with the track mute but not with the audio follow.
MBroniec
#6 Posted : Tuesday, December 1, 2020 9:12:42 AM(UTC)
MBroniec
+1 on this.
They are talking about the Automatic Audio Mixing button on the audio fader. Before I joined the forum 2 weeks ago, I emailed support about adding it as an activator. They replied the reason they don't have it is because that is usually a set and forget setting. But they said to add it as a request here and if there was enough votes, they would add it.
raugert
#7 Posted : Tuesday, December 1, 2020 11:47:56 AM(UTC)
raugert
Canada
+1 (Please add to the API XML as well)
Some Panel Builder users have also asked for this..
AudioGreg
#8 Posted : Tuesday, December 1, 2020 1:49:10 PM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
yes please...+1
I frequently find the need to toggle this on-off in some of my productions. this activator would be helpful.
RicIct85
#9 Posted : Friday, December 4, 2020 7:54:04 AM(UTC)
RicIct85
Italy
+1
PeterH
#10 Posted : Friday, December 4, 2020 9:13:27 PM(UTC)
PeterH
+1
kirik
#11 Posted : Saturday, December 5, 2020 6:02:10 AM(UTC)
kirik
Russian Federation
+1
shawntempesta
#12 Posted : Sunday, December 6, 2020 8:59:18 AM(UTC)
shawntempesta
Was thanked: 9 time(s) in 7 post(s)
+2. One for the feature. The other to offset the really unjustified salt from DWAM.
Poppa Monsoon
#13 Posted : Monday, December 7, 2020 8:32:58 AM(UTC)
Poppa Monsoon
+1 as well.
Very much “not” a set & forget option.
P
talrmd
#14 Posted : Wednesday, December 9, 2020 3:23:00 PM(UTC)
talrmd
+1
talrmd
#15 Posted : Wednesday, December 9, 2020 3:23:39 PM(UTC)
talrmd
+1
CyberNBD
#16 Posted : Saturday, December 26, 2020 1:18:16 AM(UTC)
CyberNBD
Netherlands
+1
Peter1000
#17 Posted : Saturday, January 16, 2021 8:44:26 PM(UTC)
Peter1000
Switzerland
Was thanked: 85 time(s) in 65 post(s)
+1
HuperSom
#18 Posted : Monday, February 8, 2021 7:43:44 PM(UTC)
HuperSom
Portugal
+1
Denight
#19 Posted : Friday, February 12, 2021 4:59:45 PM(UTC)
Denight
+1
dbiser
#20 Posted : Friday, March 19, 2021 4:12:42 PM(UTC)
dbiser
+1
2 Pages12>
