Hello, I needed a way to send my lyrics from OpenLP ( https://openlp.org/) to vMix for my live Show. But I don't want the "green screen way" to do that because it avoids me to use the output for a real use (only to be used for video mixing with a color Keying). So I write a small piece of software that ask the Stage display API for the current slide text and send it to vMix on prepared text/title Input. The layout is done on vMix (as I get the lyrics in raw text) and the input could be used on the overlay layer you want. If you find it useful, you can find it there: https://github.com/mbienvenue/LyricsTovMixThat's just a software that you setup once then launch it and forget. The development isn't perfect, but that makes the job done for my needs.
