Bukaj
#1 Posted : Friday, November 13, 2020 6:35:36 AM(UTC)
Bukaj
Poland
Hello
I tried hard to find shortcut for changing program from Output to Output2 or Output3 but I failed. It will be more comfortable to use keyboard shortcut instead of clicking on gear and changing output. Maybe there is no shortcut for this action
#2 Posted : Friday, November 13, 2020 10:19:49 PM(UTC)
@ Bukaj,
Try these Shortcuts:
"SetOutput2"
"SetOutput3"
"SetOutput4"
Bukaj
#3 Posted : Friday, November 13, 2020 10:56:47 PM(UTC)
Bukaj
Poland
Thank you for reply, but it is not what I mean. I know this shortcuts, but instead of changing what is displayed on some output I would like change "Program"(right top corner window)
#4 Posted : Friday, November 13, 2020 11:13:04 PM(UTC)
@ Bukaj
You can easily change the vMix Program Output to any Input you have in vMix with Shortcuts.
As such, Outputs [2][3][4] are not Inputs, unless you bring them back in as NDI Inputs, which would then be available to send to Program Output.
Bukaj
#5 Posted : Saturday, November 14, 2020 1:11:49 AM(UTC)
Bukaj
Poland
I dont want change input of outputX, but from time to time check is output2 fine and back to watching output1. I know i can inputX which is outputX put in preview to check it, but I would prefer check it as outputX not as inputX, because what signal i generare is outputX. In my opinion checking outputs prevent me from changing input which go to output
