Feature Requests
Images to keep their original size
Joined: 12/3/2013(UTC) Posts: 17  Location: Netherlands Was thanked: 2 time(s) in 2 post(s)
Hi Martin,
I would like to see the option to let image inputs keep their original size. When I add an image input, I have to reduce the zoom factor. And I have to fix the aspect ratio with the Zoom X.
Example: I want to use an image (width 200px and height 300px) as an overlay. That image must have a width of 200px and a height of 300px on a 1920x1080 output. It would be great if you can choose to keep the original size in the options menu.
I think this feature would be very useful and time saving.
Regards, Brian
Thanks: 8 times Was thanked: 46 time(s) in 23 post(s)
brian078 wrote:Hi Martin,
Regards, Brian I also agree that automatically stretching the image is a bad idea, and its almost impossible to scale it back to original pixels. To avoid this, we are converting all images to transparent full sized PNG, which is just a waste of time. Dundurs
Joined: 1/13/2010(UTC) Posts: 5,364  Location: Gold Coast, Australia Was thanked: 4785 time(s) in 1642 post(s)
You can add the images using the Photos input, just put them all into a single folder, add the folder and select them as needed. This will preserve the aspect ratio of each image.
Good Day,
I agree that with photos input it keeps the aspect ratio, but please why not in the list too ?
Using the list helps as we use many photos, backgrounds and shortcuts,
Thx
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Thx
Lists are really not intended for images : "The List feature can be used to create a playlist of video and audio files."
Well, Yes i agree, but why not making it Keep the aspect ratio !!
Originally Posted by: srioui  Well, Yes i agree, but why not making it Keep the aspect ratio !! Maybe because it is set up for video formats, maybe
GoodDay,
nope, always H.264 Mpeg 4 @8Mb
Feature Requests
