Feature Requests
VirtualAudio, Hotkeys and resolution
Joined: 5/11/2012(UTC) Posts: 23  Location: Norway Thanks: 2 times Was thanked: 6 time(s) in 2 post(s)
As I stream using "Livestream for Producers" I have some requests to make vMix even better...
1. Modify/Make a "Virtual Audio device" output that can be picked up in Livestream for Producers. (This would save me the installation of a Virtual Audio Cable)
2. Can you make the "Global" shortcuts (hotkeys) truly Global. So you don't have to worry about keeping vMix in focus? Easy to forget when you check the audio mixer or something in Livestream for Producers. (This would also save me the installation of a Global hotkey program)
3. (not so critical/important) As some other people have pointed out; resizing of the output cost CPU power. some more resolutions would be nice, 450p 540p?
Best regards KKR
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
Feature Requests
