2 Pages12>
MickeyMJJ
#1 Posted: : Tuesday, January 29, 2019 9:54:00 AM(UTC)
MickeyMJJ
Was thanked: 9 time(s) in 8 post(s)
Is it possible to increase the number of input categories please ?
thanks 1 user thanked MickeyMJJ for this useful post.
Av-Service on 10/3/2021(UTC)
MickeyMJJ
#2 Posted : Wednesday, December 11, 2019 10:01:04 PM(UTC)
MickeyMJJ
up
TBacker
#3 Posted : Saturday, December 14, 2019 2:15:19 AM(UTC)
TBacker
+1 - More tabs
P.S. - And maybe a way to hide a tab so we can put all of the constituent parts of other shots in a place where day-to-day operators won't see them.
thanks 1 user thanked TBacker for this useful post.
lnlcmedia on 10/23/2021(UTC)
MichaelKoh
#4 Posted : Wednesday, January 1, 2020 4:33:15 PM(UTC)
MichaelKoh
Singapore
+1
MickeyMJJ
#5 Posted : Tuesday, January 14, 2020 7:46:49 AM(UTC)
MickeyMJJ
Up please
MickeyMJJ
#6 Posted : Friday, January 31, 2020 11:38:23 PM(UTC)
MickeyMJJ
Please Martin
Ronald555
#7 Posted : Saturday, February 1, 2020 5:57:25 AM(UTC)
Ronald555
+1
I could use 3 extra tabs, I like to organise things.
And also: saving the current tab in the preset, so that vMix starts with this tab instead of the 'all inputs' tab.
TBacker
#8 Posted : Saturday, February 1, 2020 6:50:42 AM(UTC)
TBacker
Should it save the last tab, or allow you to set a default? If save last, you're at the mercy of the last user, which may not be good if you want to start up in a consistent state / tab.
MickeyMJJ
#9 Posted : Monday, February 3, 2020 4:26:25 AM(UTC)
MickeyMJJ
I have around 120 entries/inputs and it's very difficult to organize them with these few tabs available
nickyg
#10 Posted : Saturday, April 25, 2020 9:25:48 AM(UTC)
nickyg
Italy
+1 - More tabs
1. I think they should be extended to 12/15 Tabs!
(or more!)
Ability to select in the "input categories" tab with a check which Tab to display (in case they all cluttered the screen too much)
1a. If the GRAY tab displays all the inputs present, and in the other colored TABs the inputs (camera, logo, title, call) can be separated ...
it is possible to make sure that for example if I have in the Gray TAB example the previews of the calls, room, etc. closed (made narrow and vertical) for a matter of space on the monitor, it is possible to do that in the colored TABs where I have inserted only the calls these inputs remain open (horizontal).
In practice I would like a separate and independent management of the visualization of the inputs between TAB and TAB.
maybe in the gray tab I don't care to preview, but in the Dedicated YES tab. Now if it is closed in the gray tab it also remains closed in the dedicated tab. and it is not a good thing.
2. If I wanted to create a scene with various inputs (eg logo, time, title etc.) I would have to insert an input for each component so as to visually dirty the GRAY panel where all the inputs are displayed.
it is possible to make sure that in Multi Views, in addition to being able to select an Input (pre inserted), it is possible to load an external file ONLY in that input (for example by loading a logo). Clearly the logo I WOULD NOT like to find it in the input contents in the gray TAB.
In the sense I build a TEMPLATE BASE where I insert elements but I don't want to find them scattered on the stage below.
3. When I use the zoom sursor on the right in the lower preview in multi views, is it possible to add the hand function to move the preview with high zooms for more precise positioning?
4. is it possible to make sure that for vMIX CALL calls there is a sort of warning, popup, red dot that appears both on the Browser and on the software when there is a new chat message ??
(a sort of notice so as to make the director understand that there is a chat message or the guest called that the director has sent him a message)
Sapatrello
#11 Posted : Friday, May 8, 2020 12:17:31 PM(UTC)
Sapatrello
New user (at work).
So... is there now NO way to add more tabs? Or have I just missed how to do that?
Shawn
MickeyMJJ
#12 Posted : Friday, June 19, 2020 9:18:35 AM(UTC)
MickeyMJJ
Originally Posted by: Sapatrello Go to Quoted Post
New user (at work).
Shawn
not yet...
SoundcoreAdam
#13 Posted : Thursday, July 16, 2020 2:29:12 PM(UTC)
SoundcoreAdam
I 100% Agree... I do a live stream on Amazon Live and talk about different products and usually split them up into the categories and/or products - it would be nice if I could add two or three more when needed.
Paul Camino
#14 Posted : Thursday, July 16, 2020 6:09:14 PM(UTC)
Paul Camino
+1 I don't need a ton more. but 3 would be good to bring the total to 10
MickeyMJJ
#15 Posted : Thursday, October 8, 2020 7:05:58 AM(UTC)
MickeyMJJ
+100
Simsyuk
#16 Posted : Thursday, October 8, 2020 8:01:36 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Ability to move the tabs around would be a good idea as well (click, drag and drop).
Gunnar
#17 Posted : Monday, October 26, 2020 5:51:43 AM(UTC)
Gunnar
Sweden
+1
josephstracuzzi
#18 Posted : Thursday, November 5, 2020 1:13:21 AM(UTC)
josephstracuzzi
Canada
+1
kirik
#19 Posted : Monday, November 9, 2020 7:35:40 AM(UTC)
kirik
Russian Federation
+1, if possible find more colors =)
Howlswolf
#20 Posted : Monday, November 9, 2020 1:17:02 PM(UTC)
Howlswolf
Canada
+1
More flexibilities with Tab's would be great,
-adding tab's
-removing tab's (minimum 1 obviously)
-RGB color picker ?
2 Pages12>
