mcook75
#1 Posted : Sunday, November 8, 2020 11:59:24 PM(UTC)
mcook75
So i have been trying to create a simple volume up button (increase/decrease by 3% for example!)
I'm most of the way there, but have hit a wall! The general idea is, put the current volume level into a variable, add/subtract "X" amount, done! However when you read the volume, it's looks like it is logarithmic, not linear! i.e. if set to 50%, it reads as 6.25%
it also doesn't help that when i search for how to convert the two, most answers require the Log function, which I don't think is supported within vMix!
So this is what i have so far;
Dim vol as Double
Dim newvol as integer
Dim callerinput as integer = 1
Dim x as new system.xml.xmldocument
Dim xml as string
'.... RUN SCRIPT
xml = API.XML()
x.loadxml(xml)
'Get volume level
vol = x.selectsinglenode("//input[@number='" & callerinput & "']/@volume").value
'the maths that is missing!
newvol = vol-3
'set new volume level
API.Function("SetVolume",callerinput,newvol)
'to see if the maths works
Console.WriteLine (vol)
Console.WriteLine (newvol)
it works, right up until I need to sent the new number,
if you know of an easier way, or can fill in the maths blanks, it would be appreciated!
joedemax
#2 Posted : Monday, November 9, 2020 5:19:24 AM(UTC)
joedemax
Was thanked: 10 time(s) in 6 post(s)
C#, but this is what we do in Central Control
float logValue = (float)Math.Pow((e.Level * 1000000), 0.25) / 100;
thanks 1 user thanked joedemax for this useful post.
mcook75 on 11/9/2020(UTC)
mcook75
#3 Posted : Monday, November 9, 2020 5:33:16 AM(UTC)
mcook75
Thanks Joe, I’ll try and see if I can work it out from this! I fear the biggest issue, is that the log maths function isn’t recognised by vMix! Although I may be using the wrong syntax... programming is certainly down on my list of skills
pm
#4 Posted : Monday, November 9, 2020 6:13:19 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
thanks 1 user thanked pm for this useful post.
mcook75
#5 Posted : Monday, November 9, 2020 8:22:44 AM(UTC)
mcook75
Originally Posted by: pm Go to Quoted Post
https://www.vmix.com/knowledgebase/article.aspx/144/vmix-api-audio-levels
That’s the puppy!!!... many thanks for this!!
