MickeyMJJ
#1 Posted : Thursday, November 5, 2020 8:06:26 AM(UTC)
MickeyMJJ
Excuse me in advance for this text translated by Google translation.
To be as modular as possible, I wanted to separate several groups of inputs into several independent presets. Each preset has shortcuts which I defined locally at the preset
Once I have loaded my preset that I use as a base and want to add another preset, vMix asks me if I want to open the preset or add the ones already loaded. That works perfectly well. However, the shortcuts do not load and are not added to those I already have.
Is this a bug? The design of vMix which is so? Or can I use another method?
#2 Posted : Thursday, November 5, 2020 8:41:14 AM(UTC)
Si tu définis tes shortcuts "locally at the preset", ils ne fonctionnent que pour le preset d'origine !
Fais des shortcuts globaux mais ta méthode globale va poser problème...
MickeyMJJ
#3 Posted : Thursday, November 5, 2020 9:39:44 AM(UTC)
MickeyMJJ
Tiens, un frenchy.
Merci pour ta réponse.
J'ai l'impression que ce n'est pas implémenté cette fonction, je vais donc revoir mon projet différemment.
Je vais donc plutôt mettre tous les raccourcis sur le preset qui me sert de base, quitte à ce que certains soient orphelin du fait qu'ils pointeront sur des entrées non chargées.
