GT
Export Title with data in another preset
Hi
I build graphic in my GT Title Designer. I go link my text field with the Data manager in vmix (google sheet). After that i want to export the title with the link already done to another vmix user who have already build is preset. It is something possible or i have to redo the link with the data manager everytime i want to exchange title with another user or preset.
Thanks Doubt it , unless maybe if you have everything exactly the same on both computers. Datasource settings are saved with the vMix settings, Title stuff with presets Best bet is to name the elements in your title the same as the headers of your datasource and "apply to ALL Fields in this title" option when linking to the datasource so it's a one step process
I find the solution. You can do it by the function Append when you bring your preset. Thanks Vmix
GT
