kevev
#1 Posted : Saturday, October 31, 2020 12:05:15 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
When a camera input has other camera inputs as multiview overlays, the other camera tally's show as live even when the multiview check boxes are disabled.
For example, camera 1 has camera 3 & 4 as multiview overlays 1 & 2. When multiview overlays 1 & 2 are disabled via the check boxes on camera 1, the tallys for camera 3 & 4 show as active. If these camera 3 & 4 are not active in the output, they should not be active in tally.
kevev
#2 Posted : Tuesday, November 3, 2020 3:18:20 AM(UTC)
kevev
So is this a possible bug?
#3 Posted : Tuesday, November 3, 2020 12:55:38 PM(UTC)
This is by design. The checkbox is only for hiding the input but still keeping it in the multiview for audio mixing / tally purposes.
kevev
#4 Posted : Tuesday, November 3, 2020 2:36:15 PM(UTC)
kevev
Interesting. Thank You for the information. I ended up following one of the vMix tutorial videos and got the result I was looking for. I added a blank input, then made this input transparent. I then added to multiview 1 a full screen camera input. On multiview 2 & 3 I added other camera inputs, and zoomed them smaller.
I would like to have these 2 additional multiview overlays slide in and zoom from the bottom. Not sure how to do this. Any advice is welcomed. Thank You! :)
