Countdown To Time Trigger does not work
Joined: 11/1/2020(UTC) Posts: 4   Location: Washington
Using Countdown To Time timer OnCountdownCompleted Trigger fade to, does not work. Regular timer Countdown works great. Any idea. Or it is a bug? Thank you.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Vadim  Using Countdown To Time timer OnCountdownCompleted Trigger fade to, does not work. Regular timer Countdown works great. Any idea. Or it is a bug? Thank you. Is normal. OnCountdownCompleted works on countdowns not on clocks of which Countdown To Time is part of
Joined: 11/10/2020(UTC) Posts: 10  Location: Glasgow Thanks: 1 times
It would be nice to implement this. I could have used this feature a few days ago for automating several production countdown clocks.
Joined: 9/21/2020(UTC) Posts: 5  Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: onelifeonesuit  It would be nice to implement this. I could have used this feature a few days ago for automating several production countdown clocks.
Bump. It seems unintuitive that OnCountdownCompleted would not work on the Countdown to Time, as it IS a part of the countdown input, albeit on a clock.
Originally Posted by: Stephen Vail  Originally Posted by: onelifeonesuit  It would be nice to implement this. I could have used this feature a few days ago for automating several production countdown clocks.
Bump. It seems unintuitive that OnCountdownCompleted would not work on the Countdown to Time, as it IS a part of the countdown input, albeit on a clock. Its a clock (specific time of day and timezone) not a countdown (specific duration) ! A script can use a clock to play with
Hi Guys,
I have the same troubles and would appreciate the vMix-Team to fix this issue soon :)
Originally Posted by: vMix-Victor  Hi Guys,
I have the same troubles and would appreciate the vMix-Team to fix this issue soon :) Please read previous answers! Countdown to time CAN NOT trigger and countdown can ! is NOT an issue! use a script to trigger at a certain time of day ! see the scripting or dummies post for one
