I`m Building a VMIX Separated CG ,
Thanks: 3 times Was thanked: 11 time(s) in 9 post(s)
i`m Building a Vmix Separated CG integrated completely with VMIX 12 and you can use it on the same computer running VMIX or another computer or from another building also , The CG comes with simple SQL database , all based on flash , no need to make clicks on VMIX , just use the CG software to display what you want on VMIX real Time . and a great GUI interface too .
I will release the Demo Testing Soon here .
Regards
PS. we will add LIVE twitter feeds animation to the CG, so you can display LIVE twitter feeds from your audience .
 2 users thanked hassan yaghi for this useful post.
Joined: 11/15/2010(UTC) Posts: 99  Location: Jamaica Thanks: 23 times Was thanked: 17 time(s) in 14 post(s)
hassan yaghi wrote:i`m Building a Vmix Separated CG integrated completely with VMIX 12 and you can use it on the same computer running VMIX or another computer or from another building also , The CG comes with simple SQL database , all based on flash , no need to make clicks on VMIX , just use the CG software to display what you want on VMIX real Time . and a great GUI interface too .
Regards
Sounds good
Joined: 9/16/2013(UTC) Posts: 27 Location: Lagos, Nigeria
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hello All , If any VB advanced developer here please
Regards
Sounds great... Waiting patiently...
Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
hassan yaghi wrote:Hello All , If any VB advanced developer here please so how far are you? and whats your eta?
Beta will be posted soon , the main user interface is very simple , the beta release will be a " soccer game project " full dynamic graphics using dynamic flash integrated with vmix 12 , the beta do not include a database , so u have to run the CG on the same computer with vmix but on a different monitor , or another computer on network lan with shared data folder . all graphics has IN and OUT effects .
I really don't know my eta cause i`m working on this alone , all flash work is finished and the main user GUI is almost done , need to build the project and test it, the CG will come with an installer for the Beta files.
i`m really working hard on it but as u know its still 1 man show , all tests till now is significant .
Regards
Sorry to not know the lingo but what is a "CG"? Thanks Frank
Joined: 7/23/2013(UTC) Posts: 127  Location: North Thanks: 12 times Was thanked: 13 time(s) in 11 post(s)
cambysys wrote:Sorry to not know the lingo but what is a "CG"?
CG stands for character generator, or computer graphics. In this case it's probably a mix of both :) hassan, I could be interested in testing the beta.
Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Nice idea!
This could serve also to present dynamic charts?
Thanks: 24 times Was thanked: 10 time(s) in 8 post(s)
Hi.
Could we have an update ?
thanks
CG LIVE preview almost ready , since vmix don't open a webpage as source also , so we changed some data source feed . i don't know why vmix cant open a silly html page in the video source .
anyway , very soon i will post the preview .
Am still waiting to see the great jobs of yours
Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
I would be happy to beta test this for you also
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
Is it comparable to Casparcg, so that we can use our own templates in flash or are Theresia prebuilt ones? Also how does vMix capture it; trough desktop capture, as some sort of virtual input or on another wat? Do you have any updates on the beta?
Great idea so far!
