daverino1259
#1 Posted : Thursday, October 29, 2020 7:50:08 AM(UTC)
daverino1259
I'm new to VMix (formerly using Streamlabs OBS). I'm excited about the Call feature because that was a struggle in OBS. However, when I initiate a call with my guest the guest sees the entire stream output. This can be rather distracting for the guest because I occasionally make them full screen and with the delay it's a little weird to be talking to yourself. I would much rather they just see my camera instead of the whole feed. Is it possible to switch what VMix call "sees"? Like switch from the main output to "input 1" or something?
Thanks for your help!
Paul Fuhrmann
#2 Posted : Friday, October 30, 2020 3:54:58 AM(UTC)
Paul Fuhrmann
Germany
Was thanked: 9 time(s) in 8 post(s)
Yes it is.
Most simpli is create an an additional mixer as an input. Route the corresponding inputnumber to output 4. Define Output 4 as the Videoreturn for the callers.
You can now switch them what they need to see. It will mainly be the host/you bot if you show an videoclip wich they also need to see you can dynamicaly do that.
dmwkr
#3 Posted : Saturday, October 31, 2020 6:45:15 PM(UTC)
dmwkr
Right-click on the call input to change the video source.
thanks 1 user thanked dmwkr for this useful post.
Denny135 on 11/18/2021(UTC)
