Output from Vmix to Hockey Tv
Joined: 5/23/2020(UTC) Posts: 4  Location: Lloydminster Thanks: 1 times
I am trying to output frame rates compatible to hockey tv
they want either:
1080i at 59.94fps or
720p at 59.94.
I am unable to get their encoder to recognize this signal...
I am running the latest Dell G7 7790 computer.
My settings on my sony camera are 1080i at 60 Avermedia capture card
Anyone out there have issues getting Hockey TV to get a signal?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
What the codec and bitrate they requested?
they want HDMI input
720p at 59.94
no exceptions... not 60fps... 59.94.
I managed to change my NVIDIA settings out to 59HZ and that worked... But now i need a clean feed output hdmi on an external monitor to their system
Got it, I thought we were talking streaming.
A clean feed usually means a Blackmagic/Aja card using VMix’s external output.
Originally Posted by: Vince Beck  Got it, I thought we were talking streaming.
A clean feed usually means a Blackmagic/Aja card using VMix’s external output. AFAIK a clean feed means video without graphics overlay
They don't mind the graphics but so far ive been able to give them my computer screen with the back end of vmix as its an hdmi out. Since I have a laptop and don't want to go with the Blackmagic/aja card output, I was thinking of just going to a 2nd monitor with an hdmi output and put the 2nd monitor as a fullscreen. that way, I think... that the 2nd monitor with the HDMI output will be the input on their feed as long as I match what they want for resolution size....
Lmk if this makes sense or if there is another way
Originally Posted by: Vince Beck  I have a thunderbolt... so this would be set up through the settings/External Output then Vmix would see this as a device?
Yes, it should. I don't know about this particular laptop. Make sure you can return in case you have issues.
 1 user thanked Vince Beck for this useful post.
